Spree fuel tank
reynoldston
Spree fuel tank
Post by reynoldston »
Need to replace the fuel tank on my Spree. The used tank I got to replace it with has some rusty pin holes in it. Has anybody every patched one of these tanks. If so what did you use and what kind of luck did you have? I was also thinking about adding a fuel filter.
Johnniespeed
Re: Spree fuel tank
Post by Johnniespeed »
I cut all my old rusty scooter tanks in two, I sandblast all the rust out until it is perfectly clean, I weld the tanks back together and then coat them internally with a product called Kreem. This essentially gives you a new clean white plastic fuel tank inside a steel shell and nobody can tell of this great mod. Great for restorations and daily drivers.
I have a system or method now and can do them in about two hours. This eliminates the fuel system issues that other guys always seem to have. Also I no longer have to hunt for perfect tanks anymore.
Elite 150 64 mph for sale.
Elite 250 77 mph. for sale.
reynoldston
Re: Spree fuel tank
Johnniespeed wrote:I cut all my old rusty scooter tanks in two, I sandblast all the rust out until it is perfectly clean, I weld the tanks back together and then coat them internally with a product called Kreem. This essentially gives you a new clean white plastic fuel tank inside a steel shell and nobody can tell of this great mod. Great for restorations and daily drivers.
Just where do you cut the tanks apart, at the seam? What do you cut them apart with? Do you fill when with water first? Then what do you use to weld them together? I do have a acetylene set can it be brazed? Not very good at welding. Also where do you buy the product called Kreem?
Johnniespeed
Re: Spree fuel tank
Yes, Air saw or jig saw, use metal blade, Yes, MIG or TIG or Gas weld or braze, Yes, most every motorcycle shop or Ebay.
I have tried each type of welding to confirm that it would work and it does.
Once the tank halves are sandblasted there is no longer any danger of explosion, when sawing the tank in two, fill the tank with water to lessen the chances of explosion and personal injury, yes you could get hurt or die if you cannot understand fuel vapor ignition, I have done about ten or eleven now and no problems The tank welding does not have to be perfect, the Kreem will fill any pinholes up to 1/8 inch.
You can also Kreem without sandblasting as that is what it is intended for, but I want a very long lasting fix and I don't think it sticks well to rust, I KNOW it sticks to bare sandblasted steel.
Re: Spree fuel tank
I understand the wish to fix whatcha got very well. But in this case, why not search for a better used tank? Kreem kit alone costs more than a nice pre-owned tank, and if you don't follow directions perfectly it may not work as well in the long run. All Plastic does undergo chemical change eventually.
