Just know you should love your honda.
1man8scoots
Post by 1man8scoots »
If anyone else on here builds engines or fixes scooters other than our honda verts they understand the title. If you think your honda is being a turd, I would like for you to try doing water pumps on piaggio style engines.
I underestimated the patience that a vespa mechanic possessed.
Thank you honda for keeping it simple.
maddog
Re: Just know you should love your honda.
Post by maddog »
Mine treats me right, after 77,000 mi. it does not like the new PG stainless so the SEF pipe goes back on- I had that trans dialed in to perfection.
1man8scoots
Ha.
1man8scoots
I swap the case bolts to allens. Alot of older designed engines used Phillips set with an impact hammer. How do you torque with an impact hammer? I guess when it stops moving or moves really quick after tight you know it's done one way or another.
veedubh20
Post by veedubh20 »
I use honda bolts on my jog horzontal. I love jog!
I got a red honda sky jdm fob :wink:
Ruckenstein
Post by Ruckenstein »
But sometimes I still gotta drop a f bomb or an OH Reaalllyy Honda San. I.e. Nh80 muffler removal.
deuce217
Post by deuce217 »
graphite9 wrote:Is Maddog a bot or is he actually a human? I agree. The Hondas are so easy to work on and simple. Even doing a yahama very was a pain. Who uses Phillips screws for fasteners that hold the cases together. And the starter internals? Even the oil pump design is wonky. Hondas all the way. Simple, reliable.
He is a fembot...
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
patthesoundguy
Post by patthesoundguy »
1man8scoots wrote:I swap the case bolts to allens. Alot of older designed engines used Phillips set with an impact hammer. How do you torque with an impact hammer? I guess when it stops moving or moves really quick after tight you know it's done one way or another.
The way it was put to me was Philips head screws are a torque limiting fastener by design. The driver is supposed to jump out to prevent over tension. That's why they are a pain to remove with out an impact device of some type. Those hammer impact tools are amazing! A regular impact had n also works well most of the time. If I can't get a Phillips head screw on the first try, I stop and get the dewalt impact wth the; impact bit and usually the screw comes right out.
wentwest
Post by wentwest »
If you are going to work on Honda scooters from the 80's you need to buy a JIS compatible screwdriver. I bought a Vessel brand Megadora Impacta. With that name you know you are holding one of the world's most impressive screwdrivers, and it also actually works and does not strip screw heads. Imagine how impressed everyone will be when you whip out your Megadora Impacta.
1man8scoots
Funny enough I have several japan industrial standard drivers. I'll look into the super tool tho.
patthesoundguy
Gotta check that driver out! Thanks for the tip :-)
