01 Honda Elite- ZX headset swap, disk brake, DIO FUN
hothatch85
Re: Too many build threads- 01 Honda Elite
Post by hothatch85 »
previous owner had 7,8,7,8,7,8 combo. way to heavy
clutch has green springs and is maxed the f out. might try the yellow springs after the lighter weights.
my ruima variator was a b**** to get on and off. the ramp plate is like the same exact size as the crankshaft so you really gotta jimmy it to get it off or on. not cool.
hothatch85
I was trying to race that 171 again the other day and after holding wot for awhile I let off. When I tried to get back on it the throttle didn't respond and then something caught, I'm thinking the belt, the rear wheel locked up and the bike shut off. Then I rolled to a stop. All this happened at 50+ mph. This has only happened once before
1man8scoots
Post by 1man8scoots »
The rear wheel locked up at 50 and you made it out unhurt is awesome. Lucky!
hothatch85
It locked up, killed the motor and then un locked and I rolled to a stop. Maybe variator and belt. The ruima gets like stuck on the crank shaft
whitey
Post by whitey »
I have felt that same thing happen before too. I seized after WOT trying to see how fast I could go. I was on my Gilera Runner with a 172cc two stroke engine. Somewhere around 75mph it seized and that stopped the belt from turning which stops the tire from turning because the clutch is engaged. Eventually the clutch releases and you cost to a stop.
78 Honda Hobbit Athena
81 Puch ZA50 Polini
71 CT70 Blue
79 Z50 Red
hothatch85
The bike fired right bike up once I got stopped. I don't think I'm seizing the piston, at least I hope not!
hothatch85
Let a friend ride the elite tonight. Get a text a little later saying he was hauling * giving her all she had and it shut off. Kick start doesn't move. She's hard seized. Yayyyy
Rip_City_Spree
Post by Rip_City_Spree »
Ah crap that sucks hatch
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
Naraku sport variator
Currently 5g rollers
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
1man8scoots
Rebuild time. Do her right and never fear the seize!
hothatch85
He said he would reinbure me for the cylinder so that's cool. Good thing I ordered an Athena bore with G9 last week.
Just sucks cause I was gonna reuse this cylinder on second dio build. Now I dunno what to do with that
hothatch85
She's coming back. New af16 block with 72cc Athena kit also new motor shrouds.
Can't forget about the OEM dio wheels :)
Old tawi *
1man8scoots
You could totally jb weld that hole! Nice new build you have going!
Rip_City_Spree
Looks great
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
hothatch85
The elite rips and the plug is perfect. It's a bit of a dog on the bottom. Like gutless. How does one go about getting on the polini yellow springs on the clutch?
veedubh20
Post by veedubh20 »
lol hole on the piston :surprise:
c21 is a better pipe and match athena bore. :peace:
