cruzingratiot
Post by cruzingratiot »
cruzingratiot wrote: 7.97-1 gears installed with early 2 bearing cover
took out the 7.97
reinstalled the 8.5
couldn't get anymore top speed
and acceleration from 40 ish actually slowed down
and hurt takeoff
so in my case the 7.97-1 gears didn't help with this build
been thinking about trying another clutch
Dr Pulley HIT clutch anyone tried one ??
link to hit clutch information
http://www.unionmaterial.com/Hitclutch-19.htm
johnny248 wrote:The wind jammer pipe is the best looking pipe ice ever seen on anything. The build quality is unreal. The wds are as perfect as could ever be. quote]
Thanks
Donate Life
http://www.donatelife.net/
Thank You
Why do you think acceleration was weaker with the 8.5's?
I switched from 8.5's to 7.5's and gained some top end.
But I always thought the 8.5's had better acceleration.
cruzingratiot
Trafficjamz wrote:Why do you think acceleration was weaker with the 8.5's?
my friend I ride with
could keep up with me on acceleration
and couldn't before and he didn't change his setup
so the 8.5 worked better than the 8.0 (7.97 18x41)
and it lost top end in my case
I have a set of 7.5 (18x39 ) haven't tried yet
Donate Life
Thank You
johnny248
Post by johnny248 »
I saw go for that Dr Pully Clutch. It looks pretty awesome. I would *think* that the mechanical engagement would be more reliable, and more constant than just relying on a spring.
~UNDER CONSTRUCTiON~
bonesv
Post by bonesv »
johnny248 wrote:I saw go for that Dr Pully Clutch. It looks pretty awesome. I would *think* that the mechanical engagement would be more reliable, and more constant than just relying on a spring.
Not to correct anyone here about this but the spring is what holds it back from engagement. Centrifugal force applies the engagement on a stock clutch. It appears that those hit clutches add the extra force of incline pressure against the shoe for a better-than-stock (supposedly) clutch engagement. Very interesting concept. I would think it might be a good clutch for drag racing.
(nice windjammer) :naughty:
cruzingratiot
1450 miles on odometer is when I originally put the metzeler me1 tires on front & back
than at 4460 miles on odometer Jul 16, 2014 than I put a new front tire on
and put the front on the back so the original front tire had 3010 on it when I made it a rear
today 6785 miles on bike 2325 miles on front tire turned into rear (5335 total miles front and rear time)
decided to change rear tire could have ridden further didn't want to chance it
how far I used the first rear tire link
viewtopic.php?f=20&t=27850&start=150#p256940
Donate Life
Thank You
cruzingratiot
after getting 2 bent panels from Honda in march
gave up for a bit trying to find a good rh side
mine has a couple of small scratches most people wouldn't notice
got lucky on ebay and got one from a local Honda shop cheeper than I can buy it for online
now if I can only find a nos hood mine has a couple small scratches from my oops in march
and the hood is the only purple panel that hasn't been replaced
83450-GS7-850ZB CVR, R. BODY (TYPE2)
viewtopic.php?f=20&t=27850&start=240#p267836
new
scratches
Donate Life
Thank You
cruzingratiot
7415 miles
malossi red contra spring worn out
turning 6,500 - 7,000 rpm at 40 mph
instead of
9,000 - 9,500 rpm at 40 mph
ran ok bit it made it for lazy acceleration from 30-40 mph
( would bog than take off)
going to try other brands of contra springs
in the future
Donate Life
Thank You
1man8scoots
Post by 1man8scoots »
Use koso. It's what we run in drag bikes.
Xxbeejay45xx
Post by Xxbeejay45xx »
I have koso springs. They seem to be working really well. It feels thicker than the other brands.
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
Polini vari, clutch, springs
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Front and Rear disc brakes
Dio Live headset
Stretch and fatty rear wheel
1man8scoots
Xxbeejay45xx wrote:I have koso springs. They seem to be working really well. It feels thicker than the other brands.
They are definite thicker than the malossi red which is suppose to be a 2k spring but it is not by a long shot. I'd give it a 1500 rpm rating if anything. The koso 2k is a true 2k spring.
johnny248
Post by johnny248 »
cruzingratiot wrote:7415 miles
instead of
in the future
I have a blue polini spring with ~100 miles on it if you want to try it out.
DeanP
Post by DeanP »
Where do you get these Koso springs from?
Xxbeejay45xx
I get them on eBay.
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
AIO MotorSportS
Post by AIO MotorSportS »
Try ZTR
