New Battery, Still Got Nothin
I just installed a new battery, and nothing powers off it. Everything works when engines running just weak at low rpm's. Brake light doesnt come on, horn wont make a peep with ignition on. The new battery has 12.84V. Continuity test good thru the fuse up the frame thru ignition switch to the voltage regulator. Thats all i got dont know where else to look. all the switches are good cause everything works when its running. Any idea's for me? This is on the 01 in signature. Thanks in advance..
2001 Elite,50mm bbk, 44.1 mm mini stroker
28mm oko carb, no restriction air filter, ct intake
zx clutch, polini for ruckus vari, pg long, 7.7 gears
1999 Elite 51mm bbk, oko vari, sef ramp plate, 8.44 gears
Re: New Battery, Still Got Nothin
check your ground wires. sounds like a bad ground
thanks scootfast, just call me a idiot. i did check all the grounds prior to my post. after you answered i figured id check the wires a little closer. turns out i never hooked the ground up to the battery. with all the extra electrical items fuel pump, temp gauge, hid light, battery tender, i just over looked it... next time no * when working on the scoot...
- patthesoundguy
Don't feel bad bro. We all do that stuff from time to time. I once spent 2 hours trying to figure out why I had no spark all of a sudden on my spree... I had hit the kill switch on the barguen84 wrote:thanks scootfast, just call me a idiot. i did check all the grounds prior to my post. after you answered i figured id check the wires a little closer. turns out i never hooked the ground up to the battery. with all the extra electrical items fuel pump, temp gauge, hid light, battery tender, i just over looked it... next time no * when working on the scoot...
Johnniespeed
That kill switch gets everyone sooner or later. ( glad I'm not the only one )
Recently I couldn't get the GYRO to fire up and stay running, apparently the fuel petcock has to be turned on ( manual petcock) . Boy did I feel stupid.
Elite 150 64 mph for sale.
Elite 250 77 mph. for sale.
Johnniespeed wrote:That kill switch gets everyone sooner or later. ( glad I'm not the only one )
check grounds
- patthesoundguy
The manual petcock on a lot of stuff still gets meJohnniespeed wrote:That kill switch gets everyone sooner or later. ( glad I'm not the only one )
when me and the guys used to go out riding on the quads, and stop for breaks it would be a prank to turn someones gas off when they weren't looking. 90% of the time it would happen at a perfect time, like after riding thru water or something. it was funny watching them freak out.
- patthesoundguy
Wow thats mean but really really funny! I don't know of I could do that. I would feel so guilty and I would pee my pants laughing at the same timeguen84 wrote:when me and the guys used to go out riding on the quads, and stop for breaks it would be a prank to turn someones gas off when they weren't looking. 90% of the time it would happen at a perfect time, like after riding thru water or something. it was funny watching them freak out.
