MHR cylinder kit issue roll call
1man8scoots
Re: MHR cylinder kit issue roll call
Post by 1man8scoots »
I had a kit burn up a piston but the replacement piston worked great. I doubt it was just an airleak but you never know. Redeft was the supplier back in the day.
Mini_Stroker305
Post by Mini_Stroker305 »
Ive helped DSD with his MHR kit when he had one but never gave any major issues like these. Just couldnt get her to full peak performance not sure where he got the kit from
96 Yamaha Jog Next Zone CY50
72cc Polini Evo 2
Ruima 41.4 Teflon ministroke
Yasuni C16
24mm Polini pwk
Malossi 8:1 Primary Gears
Malossi VL14 Reeds
Polini 360 Mani
Jaingwayne transmission
Michelin S1 tires 90/90/10
patthesoundguy
Post by patthesoundguy »
I had mine melt the piston through on the first day of riding after the break in. The temps diddnt rise above 325F it was a major bummer. It had that chalky look to it.
MrJumps
Post by MrJumps »
I had a vespa 200 with a MHR 220cc piston that I paid $300 for to have installed and bored and it melted and had obvious castingmarks and the shape was off. It wasn't chalky to say, but it had a very funky pattern of ripples on the side where it had kinda gernaded.
http://www.sip-scootershop.com/EN/Produ ... +_31162510
This kit, or one very similar, but from Florida.
1man8scoots
Was it bored out stock cylinder or a mhr kit? A 221cc mhr vespa Cosa would be sweet.
MrJumps
Post by MrJumps »
1man8scoots wrote:Was it bored out stock cylinder or a mhr kit? A 221cc mhr vespa Cosa would be sweet.
It was that piston, or a copy of it and I had the local shop just bore it and port it.
jetlag
Post by jetlag »
No prob on my bore kit but my crank I had one where splines did not line up with drive face anyone had that issue. I'll get a product number up later
jetlag
Post by jetlag »
Got it local. Been running my mhr bore for 6yrs now and recently with the yasuni on it kinda wore down its compression. it's gonna need a new piston and rings soon
maddog
Post by maddog »
I got one recently from racing planet usa for my jog and never ran right so I went back to polini.
sanjuro
Post by sanjuro »
graphite9 wrote:maddog nobody can take your posts seriously...
X100,000,000
curtis966
Post by curtis966 »
I got my MHR from Wheelman and I'm pretty sure he got it from Redetf. He put about 400 miles on it and I've got about 100 on it and no problems to date.
MrJumps
Post by MrJumps »
graphite9 wrote:so it wasn't a true kit. Im just referring to the MHR's on the dio's.
nonetheless I wouldn't be happy about that. Im not stating that malossi sells bogus kits, I'm just trying to pinpoint where the counterfeit mhr kits are being sold. Malossi doesn't deserve the brand blemish.
Im betting all the clones are coming from the same factory or are made by the same people. My fake piston kit had a brand of rings called PCK never been able to find them.
Got the piston from a discount supply warehouse deal.
paulpauly7
Post by paulpauly7 »
I had a issue with the malossi small shaft crank .There was too much left to right play in the rod bearing .Stock dio was about 10 - 13 tho this malossi had 27 tho way to much float .I bought from red eft who was great to deal with he contacted malossi they said service limit was 25tho .It had a horrible rattling at idle and off throttle .I took it to a shop here and they pressed the crank closing it up to 14tho and trued it up i reinstalled and my noise was gone .
maddog
Post by maddog »
Its a track only race bore.
