1st step on my new project
DirtyE
Re: 1st step on my new proyect
Post by DirtyE »
This is nice work.
98 Elite
4 strokes are for cars
AIO MotorSportS
Post by AIO MotorSportS »
another step less
AIO MotorSportS
ped wrote:Hi AIO. Do you have a name for that stuff?
what are you building? 72cc? :shock:
hi ped,
1- no name,no lebel,no tags,sorry,(a friend give to me, few OZ,s on a Ziploc bag) :crazy:
2- yes :hi:
ped
Post by ped »
hi AIO. where can I get a spacer like that?was that pressed on or glued on?
maybe I can use Honda bond to fill the oil pump hole?
your project looks really good. :thumbwink:
AIO MotorSportS
ped wrote:hi AIO. where can I get a spacer like that?was that pressed on or glued on?
Any machine shop can make one+loctite primer +red loctite +pressed in.
You can use any metal/alum filler/epoxy ,gas and oil proof+500┬░f res +high heat fiber glass fabric
Thank you. :wink:
AIO MotorSportS
DirtyE wrote:This is nice work.
Thanks DirtyE
ped
Post by ped »
Hi AIO. so are you going to use 2 seals on the crank? On that side of the case?
AIO MotorSportS
ped wrote:Hi AIO. so are you going to use 2 seals on the crank? On that side of the case?
hi ped
No,just one,why you thinking on two?
:thumbwink:
AIO MotorSportS
Re: 1st step on my new project
hi forum
after a several month I'm back to put some time and money in my project(no money no project)
factory gasket not good :roll:
home made gasket good fit flow :mrgreen:
ped
Post by ped »
very nice work. looks clean. :thumbwink:
AIO MotorSportS
Lambretta 50mm air filter
AIO MotorSportS
ped wrote:very nice work. looks clean. :thumbwink:
Thanks Sir Ped :thumbwink:
AIO MotorSportS
Carb upgrade!
1man8scoots
Post by 1man8scoots »
We use sudoco at the shop for parts, how much was the carb through them?
