top speed
brad 30
top speed
Post by brad 30 »
i have a honda spree elite sa 50 the take off is real fast but the top speed is only 23-25 mph is this right ? thanks
se50
Post by se50 »
Is it an Elite S (Slow)? Chances are, it has a restrictor in the muffler, and the restrictor on the variator. Though, my SE50, with no restrictors at all, and performance filter only does 25.
1982 Volkswagen Rabbit 4dr 1.6l diesel (5 speed)
1987 Honda Elite SE50p with drilled out main jet, shaved head, UNI filter
1985 Kawasaki Bayou 185 ATV
1984 Yamaha IT200 enduro
1974 Piaggio/Vespa Ciao moped, pocketbike exhaust.
slowaero
Post by slowaero »
What year and model?
Look on the down tube registration plate
You need to determine if its a restricted model
which requires derestriction or whether its a 35-40mph SA50 that needs a new belt, carb work because my Aero 50 1987 is good for 30-35mph with a 20 year old belt and no mods.
ADNOH
Post by ADNOH »
My '86 Spree does about 32 mph on the flat with my 220 lbs on it. 37 downhill!
RM
brad 30
Post by brad 30 »
it is a 1997 sa50pa hope this helps thanks
berreta22
Post by berreta22 »
ADNOH wrote:My '86 Spree does about 32 mph on the flat with my 220 lbs on it. 37 downhill!
RM
its about what mine did too
1987 Spree 4400 miles 32 mph stock with my 285lb ***
MySpree
Post by MySpree »
ok, what you need to do is take the exaust off and remouve the washer welded in the flange, then remouve the kickstart cover and that off the front pully, then slip the belt off then the variator will come off, unbolt the 3 7mm screws from the back of the variator, then reinstall, simple as that, then there is a elite intake restrictor, it think its by the reed valves, i havent found it yet tho, and then reasseble, it should go 35-40
slowaero
Post by slowaero »
I agree with the above post. Don't stop with these fixes until you can peg the speedo and 97 dio should.
Spreewell
Post by Spreewell »
If your a fatty you can't get 'em going very fast, lay off the Little Debbies for awhile.
berreta22
Post by berreta22 »
Spreewell wrote:If your a fatty you can't get 'em going very fast, lay off the Little Debbies for awhile.
and quit riding the spree and walk
ADNOH
Post by ADNOH »
Does this still apply if you're 200lbs of gleaming muscle, and your 20 year-old Spree still hit 32 on the flat?
RM
