Wheel options for a 96' Elite SR?
Re: Wheel options for a 96' Elite SR?
Got the wheel tonight! Battling a migraine atm. Ill know more tomorrow.
Picture of wheel it's splines and max dia.
http://imgur.com/yyRapgp
Open comments pertaining to my scooter are entertained and promoted by me.
Thanks for the help guys!
Just ordered a 90/90-10 for this puppy.
1man8scoots
Fits like a glove right.
Clean out that tire slime ha.
Yeah that's exactly what I was thinking. Theres absolutley no way to do a Douglas wheel conversion without modifying the shock. Thats assuming their narrowest wheel is a 2+2in.
Although you might be able to put a half inch spacer between the Kymco adapter the 4" douglas wheel just enough to keep away from the shock and still squeeze it within the muffler.
Thanks!
Thanks!
Got the tire in today. Decided to go with a 90/90-10 Kenda K329.
http://i.imgur.com/cI3T1n9.jpg
http://i.imgur.com/JEn1x9G.jpg
Update:
Drove it up the rode a few times turns out the tire is infact rubbing the spring. Not quite sure what would my options are now.
- Everything stock even the rollers except KOSO variator and back wheel at this point.
- image.jpg (171.63 KiB) Viewed 10192 times
- You can see the mark on the tire
- image.jpg (94.28 KiB) Viewed 10192 times
Solution(?):
rotated spring ~a half turn. If that ain't about a beesdick of space i don't know what is.
- image.jpg (204.12 KiB) Viewed 10183 times
Yeah that will rub under load for sure. If you take the rim off and put a thick washer on the axel then the rim you can get a little more clearance.
Johnniespeed
Why not move the shock away from the tire ? Reshape the lower shock brackets and modify the upper frame. A quarter inch should do it.
Elite 150 64 mph for sale.
Elite 250 77 mph. for sale.
I reacted a little hasty perhaps. I ended up taking the spring off and sticking it in the vice and bending inbetween the 3rd and 4th turn from the botton. I threw a zip tie around a couple of spots to maybe hinder it from turning too much to let it end up in a bad spot. Sat pretty firmly without the ties. I definitely will do this the correct way as soon as I source a spring.
