graphite9 wrote:That's hothatch's future jap wheel set. I also have taida mini flywheel kit coming in. Need to get my fuel pump. Anyone have a dio fuel pump to send my way until mine arrives? I can't out plastics together. Also, since I'm installing an af16, where do I get my vac/pos signal from? Drill and tap the oil plug? I could run a mikuni but I'd rather stick with oem
Taida mini flywheel kit? Can you run lights? How much? Can you get them ? & what rear shock is that your runing? Also do you have any daytona varis?
Great work.
