Will Chinese disk brakes fit Elite?
Hi forum.
anyone know if Chinese disc brake and stem will fit 95 elite sa50?
Local Junkyard has a few Chinese scooters just wondering if any of them will work?
Thanks in advance for any info.
- 20150718_142957.jpg (153.6 KiB) Viewed 21056 times
- 20150718_142906.jpg (191.39 KiB) Viewed 21056 times
- 20150718_142859.jpg (140.23 KiB) Viewed 21056 times
Re: Will Chinese disk breaks fit Elite?
Maybe the black one with the single piston caliper? It would be nice to have disc brakes, but these may be junk?
Maybe the Vespa motor for a swap?
- 20150718_142603.jpg (224.89 KiB) Viewed 21055 times
- 20150718_143118.jpg (177.89 KiB) Viewed 21055 times
- 20150718_143226.jpg (212.36 KiB) Viewed 21055 times
The (last one) red brakes look a lot like my dd50 brakes,
1man8scoots
The vespa is a lx50, slowest 4t in the group.
Re: Will Chinese disk brakes fit Elite?
Rear disc brake
- 20150729_153409.jpg (179.01 KiB) Viewed 20965 times
- Xxbeejay45xx
Nice scooter junk yard! The front end set up will work if you use the stock elite stem and mate it to the gy6 forks. I did it to mines. I just upgraded the forks, caliper and rotor with an eBay special.
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
Polini vari, clutch, springs
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Front and Rear disc brakes
Dio Live headset
Stretch and fatty rear wheel
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
I also mated up a Chinese disc from end. Just modded my fork tube slightly and used the bearing race off of the Chinese scoot. Works perfect!
Thanks, good to know.
I wanted to find out if it was worth the trouble of cutting and welding the forks.
Or just order a front disc kit?
Most of the forks tubes that I see are either too low or too tall.
1man8scoots
Measure the fork width before you buy one. Otherwise you might get an odd ball size and no available upgrades for shock replacement. I also try to get my disc brakes on the left side like they should be. Some china bikes are right side.
G9 made a kymco zx 50 to a spree adaptation with using the sprees race and stem with zx50 legs for a clean and easy install. My spree has 12 inch rims and tires which rocks.
- Xxbeejay45xx
Good point you got there 1man, I guess I was lucky putting mines together.
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
1man8scoots
Vast majority of them are copies and work fine, but there's always a chance of getting a "one" off style.Xxbeejay45xx wrote:Good point you got there 1man, I guess I was lucky putting mines together.
I have no problems stoping my Honda's from 70- to 100 plus mph, it must be a rider thing!
1man8scoots
Yeah the problem is the rider claiming they're doing 70-100 and stopping with stock brakes is a liar.maddog wrote:I have no problems stoping my Honda's from 70- to 100 plus mph, it must be a rider thing!
What a wonderful piece of work maddog is.
WOW! 100+mph. that's FAST!maddog wrote:I have no problems stoping my Honda's from 70- to 100 plus mph, it must be a rider thing!
My old piaggio 500cc would go 100mph. but I only need to stop from 65mph.
