Dd50 rotory kit
BJM3x96813
Dd50 rotory kit
Is there any rotory kit available for dd50 motors? Are they any good? And where could I get them?
Johnniespeed
Re: Dd50 rotory kit
What is a rotary kit ? Mazda RX7 has a rotary engine. Disc brakes have rotors. Most large cities have rotary clubs.
Better to ask and gain knowledge than to remain silent and ignorant.
Elite 150 64 mph for sale.
Elite 250 77 mph. for sale.
Re: Dd50 rotory kit
Internal rotor kit from treatland.tv for Honda dio
https://www.treatland.tv/honda-DIO-HPI- ... -coil.htms
- Downsouthdio
Johnniespeed
Re: Dd50 rotory kit
Ahh, now I see.
My dirt bike buddies used to call that a PVL stator kit. Reduce rotating mass, increase crankshaft acceleration speed.
On the automotive side, Smokey Yunick was a big promoter of reducing rotating mass, he had a pretty good handle on increasing performance, dont think he dabbled in the two stroke world though.
BJM3x96813
Re: Dd50 rotory kit
Yeah I can get my hands on a taida. Any feedback from them from anyone? And do you need to mod a dd50 block for it to fit?graphite9 wrote:ive been down this road, the only kits that work are taida, daytona and koso. Koso and daytona kits, if you can get them are $550-700. Taida is $299 and I have a few coming in to test. Someone in hawaii is selling the MVT modofied to fit, but what he doesn't realize is it won't fit. People should install things personally before advertising they work.
Re: Dd50 rotory kit
If you shave the stator bell you will lose top end, if you use a billet PG front face you can still gain off the line and top end.
Re: Dd50 rotory kit
so the lighter mass helps with torque off the line and at higher rpms? Sign me up..
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
50mm BBK (tai)
V-8 pipe
Re: Dd50 rotory kit
Interesting....pretty sure I saw someone post that it fit, personally have seen it and done it , the only real issue is using it for air cooled requires a SMC rex or rexy fan as the stock fan is too wide and will hit the shroud, the original bracket failed almost instantly , the new custom ones shouldn't be a problem, but you never know all things fail especially experimental onesgraphite9 wrote:ive been down this road, the only kits that work are taida, daytona and koso. Koso and daytona kits, if you can get them are $550-700. Taida is $299 and I have a few coming in to test. Someone in hawaii is selling the MVT modofied to fit, but what he doesn't realize is it won't fit. People should install things personally before advertising they work.
Remember,everyone is human,even if there stupid!
1man8scoots
Re: Dd50 rotory kit
Zombie on kymco forum did the mvt many years ago on a sc10as. It absolutely does NOT fit with out fabricating a collar. Will NOT fit with out fabrication.
Re: Dd50 rotory kit
Keyway are to set timing, but not needed, we have had the "taida" version since last year July I think? It's not bad but there are issues some major some not
First is the timing on the mag is set advanced, idk why but the"trigger" point is about 3/8 to 1/2" forward of a stock mag.
Second is the reliability, some last 6 months most wont, some fail with in 5 miles, how many kits are here? I personally brought in 30 and sold all but 1 which I used for mock up.
Third the fan that ones with it will explode on initial use- don't bother trying
Forth no timing adjustment, can slot the bracket or the pickup or both, I even attempted to have brackets made to do this
1man8scoots
Re: Dd50 rotory kit
What do you mean by forward of stock trigger
Re: Dd50 rotory kit
Imagine the stock trigger bump on the mag being 3/8 to 1/2" longer at the beginning, that would advance the timing "X" amount of degrees and that's exactly what they did on taida kit1man8scoots wrote:What do you mean by forward of stock trigger
Re: Dd50 rotory kit
1man8scoots
Re: Dd50 rotory kit
That's not adjustable? I'll have a taida here soon, it's nice to know the short comings before I install it on an engine I'm not going to run before it's shipped.
