Af16 oil pump plug (delete) methods?
I know everyone installs them diffrently , as in making a braket to hold it in place , or simply using jb weld or honda bond to seal it in place . I would like to get diffrent ideas from you all , pictures would be great since ive seen HMP honda bond them into the block . I mite go that route but i would like anyones personal opinion
Re: Af16 oil pump plug (delete) methods?
I wouldn't trust Goo alone to keep that plug from flying out and embedding itself in your battery. The Goo is just for seal "insurance" but you need a big washer or some mechanical retention bracket.
you can use the stock oil pump up to 76cc safety wired on full, just ran it and it was perfect, I should run the Japan DIO zx conversion trans which I have done 25 yrs ago on my 87 aero......
