1985 Spree AF16
Re: 1985 Spree AF16
I also have another exhaust on the way. Unfortunately it won't be here til late this week. Its a sidebleed Simonini. I couldn't find much info on it here so why not give it a try. Usually sidebleed pipes are quieter so if all goes well it will go on my daily elite.
1985 Spree AF16: viewtopic.php?f=20&t=31053
2001 Elite Daily: viewtopic.php?f=16&t=31397&p=272223#p272223
Hppowdercoatings
Re: 1985 Spree AF16
Looking Good....Ben L. wrote:Finally made a little progress... Rebuild the bottom end with Malossi crank, installed a corsa, Naraku intake, CP polini 21mm carb, zx trans, polini vari, and my pg long pipe. The bike is absolutely nuts! This coming saturday the local scooter group is hosting a drag racing event at the drag strip. I gotta hurry and get this thing tuned. I'm gonna try going to 9:1 gears and see how it does.
2001 Elite 72cc...http://www.hondaspree.net/phpBB3/viewto ... =4&t=31369
1984 Spree "Little Evil" 125cc AF16.. http://www.hondaspree.net/phpBB3/viewto ... 16&t=31569
Re: 1985 Spree AF16
The bike has been running good all week with 95 main jet. Very crisp throttle. Today I took it for a spin and it kept dying at the stop lights and not wanting to restart. I'd kick it over and it would backfire and die. Finally got it running to get home but couldn't let the engine idle down.
Is my idle jet too big? It seems like a rich condition to me. I haven't even looked at what size it is but ordered a full set and they came in today. My simo pipe also came!
Re: 1985 Spree AF16
Could you give me some advice on how you mounted the af15 and if you needed any brackets to do it ? I just got a 86 and have a af15 coming to put on it! Thanks in advance
- image.jpg (156 KiB) Viewed 8553 times
Re: 1985 Spree AF16
You need the af16 motor mount. Just have to shave some material off one side. Check the wiki on this website for the details.
Re: 1985 Spree AF16
That af16 looks perfect in the Spree. No one would even know. Nice sleeper
~UNDER CONSTRUCTiON~
Re: 1985 Spree AF16
May be a tough one. But I had the idea of a stock wheelbase dio swap spree and was wondering if you had a picture of the mount you used and what the mods were
Re: 1985 Spree AF16
I can get some pics. I actually am parting the bike and might sell that mount.
- burnt_toast
Re: 1985 Spree AF16
How'd it go at that dragstrip? Just curiousBen L. wrote:Finally made a little progress... Rebuild the bottom end with Malossi crank, installed a corsa, Naraku intake, CP polini 21mm carb, zx trans, polini vari, and my pg long pipe. The bike is absolutely nuts! This coming saturday the local scooter group is hosting a drag racing event at the drag strip. I gotta hurry and get this thing tuned. I'm gonna try going to 9:1 gears and see how it does.
So what direction are you taking this build now? That PG Long looks so good on there..
projects galore
Re: 1985 Spree AF16
The race was cancelled due to rain. Most of the parts I'm selling came from this build. The spree will get sold complete minus motor ready for another af16 to bolt right in.burnt_toast wrote:How'd it go at that dragstrip? Just curiousBen L. wrote:Finally made a little progress... Rebuild the bottom end with Malossi crank, installed a corsa, Naraku intake, CP polini 21mm carb, zx trans, polini vari, and my pg long pipe. The bike is absolutely nuts! This coming saturday the local scooter group is hosting a drag racing event at the drag strip. I gotta hurry and get this thing tuned. I'm gonna try going to 9:1 gears and see how it does.
It was just too small and skiddish for me with that setup. I like the Elite because its heavier and much more stable.
Revolutionary
- Goped
Re: 1985 Spree AF16
Looks like a fun build!
