sym dd50 with af16e engine?
- chamisataza
- Goped
i have a sym dd50 i exchange it with a honda elite engine( af16) on the fuel pump of sym dd 50 one hose is connected to the carb and one is near/under the oil pump/injector of sym dd50 but on the af16 engine there is no nipple to put on on that other hose,i don't know what to do. what will i do on the extra hose of the fuel pump pls help
- Downsouthdio
Re: sym dd50 with af16e engine?
What was wrong with the sym motor? You need to re-tap you manifold for vaccum
Honda super dio
Corsa
26mm
Sparrow
Corsa
26mm
Sparrow
- chamisataza
- Goped
there is nothing wrong w/ the sym motor ,what do you mean re-tap manifold vaccum
- chamisataza
- Goped
how do i do that
- Downsouthdio
Like this,if you are running a fuel pump ,you need to tap your manifold,like you see
On the picture
On the picture
- image.jpg (207.88 KiB) Viewed 27512 times
Honda super dio
Corsa
26mm
Sparrow
Corsa
26mm
Sparrow
- chamisataza
- Goped
i have that on my ct manifold but its not located there on the picture its located at the top can i put tap it there?
- Downsouthdio
Ok,no if you are running a pump,it needs to be where you see it in the pic
Honda super dio
Corsa
26mm
Sparrow
Corsa
26mm
Sparrow
- chamisataza
- Goped
Ok so what will I do on the top nipple close it?or leave as it is.
- Downsouthdio
- chamisataza
- Goped
Thank you sir...
- chamisataza
- Goped
thanks g9
- chamisataza
- Goped
do have any idea what size of nipple port and where to buy it thank you..
Jealous of your reed cageDownsouthdio wrote:Like this,if you are running a fuel pump ,you need to tap your manifold,like you see
On the picture
~UNDER CONSTRUCTiON~
I would get something similar to the size on your pump?chamisataza wrote:do have any idea what size of nipple port and where to buy it thank you..
You can get these brass Barb fittings at any hardware store in the plumbing side. You will also need to get a NPT tap for whatever size you end up going with.
- chamisataza
- Goped
thanks j248 ill go to lowes
