Upgrading Front Brake Assembly On 87 SE50
Drifter562
Post by Drifter562 »
Hey guys I have an se50 and I have a 94 elite brake assembly what do I need to make this possible do I need sa50 brake cables? Can I keep the se50 brake cables
Drifter562
Re: Front brake conversion
I meant to say that I have a front brake assembly from the 94 elite Sa50 that I want to put on the 1987 Honda elite Se50 that I have.
What do I need from the 94 elite to make this possible ?
Re: Upgrading Front Brake Assembly On 87 SE50
I bolted that bad-boy onto my 1987 Aero. It needed only the Met (or later-SA50) wheel to install. Cables, including Speedometer fit as-is. Can't guarantee that's the case with your SE50, but seems likely.
Drifter562
Wow it was actually easier than I thought just removed the front brake cable and speedometer cable from both hubs and the hub came right off when I started removing the wheel. I switched the brake hub and presto nothing too it.
