mini stroker
mini stroker
What is considered a mini stroker. Not clear on this.
Re: mini stroker
It's a crankshaft with longer-than-stock (41.4mm) stroke, but that you don't have to bore the crankcases for oversized flywheels. Typically a 44.1mm stroke is the biggest crank that'll fit without enlarging the crankcases.
1man8scoots
Re: mini stroker
46.4 is the largest you can go on an af16 before cutting the crank wells. You also get to cut the front area with 46.4+ so on the stroke it doesn't hit the case.
Currently 2ab has a 44.4 crank but fabrizi and mazachulli no longer produce 46.4 cranks. I believe 2ab has the biggest mini at 44.4.
Re: mini stroker
as a44.7 is normal kit, what r-u running?
superfast1234
- BMX
Re: mini stroker
Why is cb900 posting for me?
Re: mini stroker
About 3 years ago I was actually running the ruima 44.4 I didnt need to cut the case/enlarge it.
1man8scoots
Re: mini stroker
No need to cut the case like I said for a 44.4.
