Clutch Question
Clutch Question
Does anyone know if a clutch outer / clutch / driven pulley from an 86 Spree will work on an 84 or 85? I am not sure if they were the same throughout the four year run of the spree. Nothing is noted in my shop manual. I am seeing that the drive pulleys are different, so I am just wondering. Any insight would be greatly appreciated.
Re: Clutch Question
Online vendors make the parts fiches available online. You can check part numbers. That said, I would be surprised if the years don't interchange.
Re: Clutch Question
Looks like the clutch end uses the same part numbers 84 and 86. The drive face is different part number but uses same belt, so should interchange.
Re: Clutch Question
I want to thank you guys for your responses. It is greatly appreciated!
Re: Clutch Question
I've had just a whole bunch of Sprees and the clutch is one of many parts that will fit all years. Ya just can't ride a Spree without smiling.
