So I bought a kick starter. I need information on how the * it is supposed to work.
I know i have to unbolt the old one and put a gear on from honda for $40.00 is that all i need to do. The guy i bought it from said i should oil her up real good.
Thanks alot guys.
I Bought a kick starter need information
- asunamazda
- Goped
reckless504
- Goped
yes there is a special starter gear you have to by. it just goes in place of the other starter gear and it looks the same besides the kickstart gear has little square indents around the middle so the kickstart has somethin to grab onto. and im sure u can find them cheaper on ebay then $40 but yes that is all u need is the kickstart and the gear.
1986 Honda Spree w/ pulley mod clocked in at 37mph hauling 175 lbs. Don't believe me? lets race!
Oil up what?? I just installed one on my 85. I bought a seized motor with case on eBay for $20.00, which had never been apart, so the starter gear was still there. It`s suppose to be a dry area due to the belt so I cleaned it out really well before installation. Works excellent and should help if the battery goes kaput!! Have some extra parts left if anyone needs something. HB32
