2 strokes and they are done. Damaged engines pix.
I wanna see the craziest 2 stroke seize marks, cracks, blown pistons, crazy grenades, anything destroying your cylinder.
Even tiny marks are what I wanna see here.
Crank splines destroyed? Post it.
Cranks snapped ?... please post it up.
Anything is appreciated!
I would also like if you included why the _____ happened.
I am doing a project for my machinery and photography class.
I am doing damaged motor parts and what's better than 2 stroke?
Also, if you are too shy to post up a mistake you made, don't worry about it.
Everyone makes mistakes, just the true real people admit them and accept it.
Just like how I locked up my spree.
2021 DRZ400sm
2021 DRZ400sm
Re: 2 strokes and they are done. Damaged engines pix.
Aero 125 piston after 22 hours of continuous running.
- Ruby piston 001.JPG (101.46 KiB) Viewed 11611 times
I remeber seeing that, brutal stuff. Love it! Thanks motormike!!
2021 DRZ400sm
2021 DRZ400sm
- patthesoundguy
I'll dig up what pics I have for ya of my spree big bore kit with the pieces of Reed holder spring that killed it and my roastesd piston with the hole in it from my mallsoi mhr af18
- patthesoundguy
Found this post from 2010 not mine but I had replied to it so it was in my posts while looking for some of my pics
viewtopic.php?f=3&t=14101
Ok thank you very much!
2021 DRZ400sm
2021 DRZ400sm
- patthesoundguy
Another one, stripped splines on a spree crank, again not mine. viewtopic.php?f=3&t=25454
- patthesoundguy
Here is the post of my spree big bore kit that ate the reed spring from the CT intake viewtopic.php?f=3&t=28401&start=15
Dang, thank y9u!
2021 DRZ400sm
2021 DRZ400sm
That's a factory ct mani reed cage? Mine was a 6 petal, but still plastic. Did yours come in a koso package, patthesoundguy?
- patthesoundguy
That was a plain ct no name inake I knew I should have taken those springs off before I ran it. I was worried about the screws coming loose so I put thread locker on them, a lot of good it did when the spring just broke off at 11k and got munched up in the intake lol the cylinder is in okay shape may salvage it someday
Thank you every one who submitted photots I got a 87 on the project all b3caus3 of spelling errors. My dyslexia causes that smeh
But anyways it came out really well and I think I owe you guys a big * thankyou!
2021 DRZ400sm
2021 DRZ400sm
Ouch, but still a neat encounter.
2021 DRZ400sm
2021 DRZ400sm
You may have already seen this... Came out of the spare AF18 bottom end I got with my Dio
- 20160131_155542.jpg (125.51 KiB) Viewed 11243 times
