STARTS GOOD BUT WONT STAY RUNNING
brad 30
Post by brad 30 »
I HAVE A 1997 SA 50 PA IT WONT STAY RUNNING WHEN I TRY TO GIVE IT GAS IT STALLS I TOOK CARB OFF CLEANED PUT BACK TOGETHER SAME THING REMOVED THE EXHAUST STILL WONT STAY RUNNING HELP!!!!!!!!!!
MySpree
Post by MySpree »
try seeing if your spark plug is good, and cheack your compression
brad 30
GOOD START but no go
Post by brad 30 »
i replaced spark plug runs good until i give it gas then bogs right down carb is cleaned now wat ? comp is good help please
brad 30
still no go
Post by brad 30 »
ok i removed all hoses to carb also removed tank cleaned replaced filter starts then when i give it gas no go
MySpree
Post by MySpree »
ok does it idle really high? clean your carb again, like manually, then run seafoam through it while its idleing, have you decarbonized your cylaner head? or ecaust port?
brad 30
Post by brad 30 »
the idle sounds normal cleaned carb again removed every screw blew air in all ports same thing. what is seafoam and where do i find it, also i will have to do hame work to find out how to decarbonized cylaner head or ecaust port is this what is sounds like?
brad 30
Post by brad 30 »
where can i find out how to decarbonized cylaner head or ecaust port
myhonda
Post by myhonda »
brad 30
Post by brad 30 »
after clearning carb again and running seafoam in with the gas started good but when i gave it gas it wont stay running after reading some posts i found something to try i removed the bystarter and put finger over the hole and it ran good could this be the problem after it warms up ? i put 12 volts to the bystarter and it wont move problem repaired? maybe?
