To make a long story short, I don't trust NOTHING about a 2 piece main bearing set I don't think my bearings are bad but I am going to visually check them soon.
Anyone have links to af01-05 crank bearings?
the correct case number is af01 though Honda the clone PGO case number is kp01 I wish to install heavy duty one piece main bearings set on a partial case split. I also plan to hand polish the crank on a desk.
Everything else is gravy work,
If I verify that just the seals bad and budget is low I'll just replace the rubber proportion temporarily til I am ready to split it again.
Making her reliable enough to get my endorsement for a bigger build possibly a 100cc nq50 bbk if the boltings match but that's future talk.
Hit me up with those seals and bear kits one piecers and 2 piecers please I'm logging to get on AF forum and modern buddy.
Crank bearings nb50m 83-84 model copy questions.
- Goped
People playing with my clone I let it slide with em, still tipping on 3.0's belt ramping the CVT ON PGOS!
Too quick, TURN UP!
Too quick, TURN UP!
Re: Crank bearings nb50m 83-84 model copy questions.
dood - imho take your engine apart and check bearing n seal sizes first. PGO maybe used different sizes
The bearings will have a number stamped on them, usually on the face of the outer race.
This is a standard system (like Dewey is to books) and relates to the various bearing dimensions.
Use this number to get exactly what type of bearing you need.
1983 Melody Deluxe II / ND50MC
1984 Melody Mini / NP50D
1979 Simson Schwalbe KR51/1 (think 2 wheel trabant/ East German Honda Cub)
