'92 Dio SR Build
Hksdio
Re: '92 Dio SR Build
Post by Hksdio »
Ok so i will do the pin test, is the general concensus that thethe clips are in the correct position?
Also is it a good idea to put hondabond on the base gasket?
tazland001
Post by tazland001 »
Hondabond and yamabond are more for engine cases. For example, the yz85 does not have a gasket in between the case so you yamabond to seal the cases. Most of the time I just use the base gasket as a dry gasket. I have only had to use sealant a few times on a base gasket. Once was on a yamaha breeze but other than that it is pretty much a dry gasket install. Now I do use copper coat on head gaskets on BBK's for dirt bikes but your head gasket will also go on dry.
taz
Hksdio
Post by Hksdio »
So customs sent my Hondabond back to america.
ha. ha.
So im waiting on permatex grey before i can seal up the gear case and Intake manifold.
recieved my new front panel today and added a little decal.
that is all the progress for now but im hoping to have her started up for the first time this weekend! eek.
Also, i did the screwdriver test on the pin and put decent pressure and nothing moved so im going ahead bravely.
veedubh20
Post by veedubh20 »
prematex black is better than grey
MrJumps
Post by MrJumps »
Customs can be a b**** at times, they once shipped my honda injector oil back because it was 1 oz too many. <3 customs.
2021 DRZ400sm :worship:
MrJumps
Post by MrJumps »
Got the tazland kit just now, cant wait to build it up! Speaking of, how is your kit doing yet? Get it running yet, heat cycles?
Hksdio
Post by Hksdio »
congrats jumps!
so i spent today doing various things,
-drained tank
-reinstalled engine
-ran new throttle cable
-fairings fairings fairings
but she started first time once i lifted the choke.
VIDEO AT URL BELOW:
https://www.flickr.com/photos/averyclev ... ed-public/
the idle keep hanging once revved slightly, i adjusted the mixture and seemed to fix it, will look into it after a few more heat cycles.
running 30:1 premix.
MrJumps
Post by MrJumps »
d***, again nice camera work, and its clean af.
Ultraliner
Post by Ultraliner »
Nice little vid clip mate, shes sounding GOOOOOD!!
Hksdio
Post by Hksdio »
I think i may have fried my electric start.
I will use kick start from now on.
MrJumps
Post by MrJumps »
d*** how so?
Hksdio
Post by Hksdio »
i think the stock starter just got the power to turn over such a beast.
on the plus side my TTO gauge arrived so i can now monitor temps!
2min heat cycle tonight then 5min cycle tommorow.
Ultraliner
Meant to ask, is that rear shock you have fitted the one that sits close to the back wheel or did you source another?
Hksdio
Post by Hksdio »
It is, i will go for my first ride this weekend and check the tyre out to see how bad the rubbing is.
so today i cut the back fender off and reinstalled all the fairings and installed the new TTO gauge.
compared with out she looked when i got her its a world of difference.
very happy with tto gauge and left it on farenheit reading so the forum temps would mean something to me.
here is a video showing the temp rising rate for the 5-10 minute heat cycle.
VIDEO AT URL BELOW:
https://www.flickr.com/photos/averyclev ... 861577859/
please excuse the autofocus i have upgraded my camera and have to deal with the kit lens untill i can afford some primes.
Hksdio
Post by Hksdio »
build is going to take a while longer.
it seems the clutch must be super worn and slipping, it takes full throttle just to move at all.
i have checked the slide and its opening perfectly with the throttle.
i also need to source a rear brake spring since i must have lost it.
