-tires
-tubes
-petcock (was broken and gas was pumping through to the exhaust, oof)
-front brakes
-rear brakes
-front brake lever and cable
-speedo cable
-front blinker bulbs/lenses
-rear combo light
-cleaned the carb about 12 different times before getting the pilot jet clear and usable
-new battery
- new front panel
-new floorboard
-side panel (was given one with bike)
-turn signal relay
-new speedo display and switches
-disassembled and cleaned push button start
-cleaned starter relay
-rewired some chewed up bits (hopefully a critter and not a person)
-new kick-start
-new grips
-mirrors
-new ignition
-oem airbox to replace uni filter setup
-SSS exhaust
-ruckus variator
-learned tons about wiring and tons about carburetors
-the service manual is now my top read of all time
Upon receipt:
Now:
