New Spree Build..AKA.."Little Evil"..125cc Hard Tail...
1man8scoots
Re: New Spree Build..AKA.."Little Evil"..125cc Hard Tail...
Post by 1man8scoots »
If you get the cylinder before I leave town and want some port work done let me know. It'd save shipping out there. I need some parts coated so trade work if you're up for it
Hppowdercoatings
Post by Hppowdercoatings »
1man8scoots wrote:If you get the cylinder before I leave town and want some port work done let me know. It'd save shipping out there. I need some parts coated so trade work if you're up for it
Sounds Good. I will Text you as soon as it gets here..
Hppowdercoatings
Project "Little Evil H2O" started.. Just got the Taida 52.6mm Cyl back from 1Man after his magical port work..
URL=http://s52.photobucket.com/user/RNMHRD/ ... .jpeg.html]Image[/URL]
MrJumps
Post by MrJumps »
You must have balls larger then the spree itself. Goood luck on that crazy thang. :bowrofl:
2021 DRZ400sm :worship:
Hppowdercoatings
Couple upgrade parts arrived today ...
MrJumps
Post by MrJumps »
Better drill a solid slick onto that back wheel ;P
Just Joel
Post by Just Joel »
Yeah the unported Corsa feels insane on my spree, I can't imagine what this setup will be like :surprise: :twisted:
84 Honda Spree... The plastic at least.
MrJumps
Post by MrJumps »
Excuse my language but that is f***ing stupid. But I love it and I want it. Can't wait to see it done. :rock:
Meloshameless
Post by Meloshameless »
If you even breathe on that throttle , tires coming up and panties going down.
2000 Honda SR (purple swurp)
corsa
naruku
polini vari 5.5 gram
zx trans
Yasuni C16
Hppowdercoatings
Started on the Taida W/C install...
Hppowdercoatings
Got the Rpm 9-Spoke Front wheel Powder coated & Tire mounted..
FYI I'm still looking for a Rear Rpm 9-spoke wheel for Dio?????
Hppowdercoatings
Little Evil's Rad setup almost done.. Have to get a overflow Tank & Wire Fan
1man8scoots
Neat I cat wait to hear how you like that cylinder. I have to run my lc set up soon too.
Peteyparado
Post by Peteyparado »
I've almost got the same set up.. Wonder what your main jet size an slow jet?? Are u running a 30mm carb..
86 aero af16 swap. 121cc water cool.
Polini 30mm carb
Naraku mani
Scorpion stroker pipe
Stage6 CDI
5gram rollers
Keli high speed Variator
6.1 gears
94mph
Hppowdercoatings
Peteyparado wrote:I've almost got the same set up.. Wonder what your main jet size an slow jet?? Are u running a 30mm carb..
Actually I'm running a New Polini 32mm Carb..
I will check on the Jetting and Post...
