dd50 sym build
edit.. have to resize image
- Florida Antique
Old and the new, 26 years difference
- Oldandnew800x600SM.jpg (206.97 KiB) Viewed 32410 times
'83 Honda Aero 80
'84 Honda Aero 125
'05 Yamaha Zuma (dual headlight mod)
'09 Yamaha Vino Classic 50(one of them newfangled 4 stroke things)
http://scooters4hooters.com
'84 Honda Aero 125
- 20150423_023413.jpg (175.72 KiB) Viewed 32347 times
- 20150423_023857.jpg (172.84 KiB) Viewed 32347 times
Its not a 50cc but it's very comfortable.
- 20150626_145621.jpg (180.49 KiB) Viewed 32254 times
I did cut the Exhaust pipe to make it a shorty
Reflex 85mph
metro 35mph
94 elite SR 55mph
spreedio 65mph
metro 35mph
94 elite SR 55mph
spreedio 65mph
My 88 Elite. Stock cylinder, ruckus variator and a custom 3D printed air intake. Does great on these San Francisco hills.
- SHRED
- Scoot.jpg (139.66 KiB) Viewed 32140 times
xXsHrEdXx
Very understated and clean. 3D printed air intake? Do Show & Tell!
In a response to wheel man:
I work at a 3D printing shop in San Francisco with access to several high end and consumer grade printers. I had this old k&n laying around and decided to put it to use (my stock airbox was also thrashed and not sealing correctly). Needless to say the filter did not fit the stock carb. I took it upon myself to design and print a (bellmouth) type mount for the filter to fit on to the carb, I used Rhino for the design work. The first iteration is the white one you see below. It was getting way to much air and bogging the high end down. The walls of the print were not that thick and got gas on the printed part immediately, eating away at the plastic. On to round two, I thickened the printed part up quite a bit. Still the same issue of gas eating away at the plastic. After 6 or so iterations I settled on the metal looking part. The walls were very thick, I wrapped the print with metal duct tape and made a flat section for a hose clamp to grip the part onto the carb. I ended up having to tape the filter up a bit as it was getting too much air and bogging down. Scoot picked up a little grunt and has a custom intake. I am very happy with how it turned out!! Now Im trying to think what I can do next! Any suggestions are welcome!!
- 4.jpg (56.51 KiB) Viewed 32130 times
- 3.jpg (67.31 KiB) Viewed 32130 times
- 1.jpg (88.94 KiB) Viewed 32130 times
xXsHrEdXx
A total of 6 iterations.
- 2.jpg (122.03 KiB) Viewed 32487 times
xXsHrEdXx
Just wanted to show off my latest mod. Some LEDs for more night visibility!!
- Screen Shot 2015-11-08 at 6.12.12 PM.jpg (242 KiB) Viewed 32428 times
xXsHrEdXx
- Rip_City_Spree
The "GOOCH"
- image.jpeg (44.23 KiB) Viewed 32371 times
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
Naraku sport variator
Currently 5g rollers
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
Ultraliner
A spot of night time running in
- Night run in.jpg (163.24 KiB) Viewed 32337 times
