Dd block ported to match stock crank
Which bore should i put on?
Ported contessa to match corsa or minor ported corsa
Set ups are:
Kelly pulley kit
Sef ramp
7.4 gears
1500 center springs and blue clutches
28 oko carb
6.5 and 7.5 weights, pg long
Small teeth belt
72cc builds
Meloshameless
Re: 72cc builds
You would think the corsa since its factory ported, but fluck it, try em both.
Try the contesticle first, that way when the corsa ends up being better you won't have to switch back.
2000 Honda SR (purple swurp)
corsa
naruku
polini vari 5.5 gram
zx trans
Yasuni C16
corsa
naruku
zx trans
Yasuni C16
Re: 72cc builds
If your going to spend the money, do it on the corsa and do light porting on the block and bore.
eight08boy
- Goped
Re: 72cc builds
Run 69 start on yellow yellow clutch an center quick 72 in no time but then again that with scorpion
Gjino Kanahele
U asking cherry price u better have cherry s***
