Yamaha jog
Meloshameless
Re: Yamaha jog
Which bike in the pic is faster, down south's dio or the jog?
2000 Honda SR (purple swurp)
corsa
naruku
polini vari 5.5 gram
zx trans
Yasuni C16
corsa
naruku
zx trans
Yasuni C16
NB50clonePGO6GOD
- Goped
Re: Yamaha jog
rakfint wrote:How fast do these things go currently? (curious I have used the engine from a 93 Jog in my Spree and am currently struggling to get it tuned right)
Nb50 84- 40mm 39.3 93 jog 40mm x 39.2 as well matches relli difference is jog has bigger port
40-42 stock with tuning jog is better for bigger carbs due to wider ports the airs there the gas is the catch.
Look at my DOW
AEROS USE SMALLER PORTS,
place a acura by a Ford and see the difference visually hogs require more air/fuel smaller requires less. Stock vs tuner.
Zuma's and ruckas get up to 40-47 mph stock.
People playing with my clone I let it slide with em, still tipping on 3.0's belt ramping the CVT ON PGOS!
Too quick, TURN UP!
Too quick, TURN UP!
