Performance 2.75-10 Tire - is there such a thing?
burnt_toast
Post by burnt_toast »
So the stock rubbers on my SE50 are weather cracked to * and thoroughly due for an upgrade..
I'd like to get some that I could really feel more comfortable taking hard turns in, leaning and such. Basically just something that'll allow me to push the bike's limits a bit more safely.
However, I can't seem to find much in the 2.75-10 tire size. Closest I've found is The Michelin S1's in 90/90 but not sure if that will fit. Would like to keep OEm size but still have the performance, if at all possible. They seem to have 80/90 as well, but not in US from what I can tell.
If you guys have any tiny tire scoop, I'd appreciate it
projects galore :nerd:
burnt_toast
Re: Performance 2.75-10 Tire - is there such a thing?
I think best I've found is these bridgestone Hoops, what yall think of these?
http://www.amazon.com/Bridgestone-Scoot ... B005J8WN4Y
Kustomkarma
Post by Kustomkarma »
burnt_toast wrote:I think best I've found is these bridgestone Hoops, what yall think of these?
Speed rated at "J" which = 62 mph...not bad.
burnt_toast
Kustomkarma wrote:Here's a couple more options.
http://www.bikebandit.com/tires-tubes/1 ... 1?m=112329
I did see those, but thanks
that's what im saying! Hoops looks to be the sportier of the 3 too. I think I will go with them. Let you guys know how they turn out :2thumbs:
CalvinB
Post by CalvinB »
The Kenda one in that size is pretty good, really cheap, decent wear, good grip. The Hoop is pretty soft, more grippy, heavier casing, wear is slightly worse than the kenda, but pretty good still, only down side is price, but its not bad. The S1 is probably the best, but it's near impossible to get to seat using tubes as it only comes in tubeless in 10 inch.
The only thing grippier than the S1 would be a slick and they are $$$, but you can get them if you really want. I have not used them as they are about $110 each plus shipping from some place called Europe, but I'm sure you could really rip on them.
'93 Yamaha Jog SOLD
'86 Honda Spree "problem child"
'94 Yamaha RazZuma viewtopic.php?f=20&t=32666
Great report CalvinB... :thumbwink:
I like both Shinko and Vee Rubber for street use.
Bridgestone Hoops description you give persuades me to buy a pair next time.
None of these 10-inch tires will wear very long on the rear.
Might have to buy a S-1 for any tubeless wheel in the future.
I like the Michelin Gazelle that I run in the 17"-18" sizes.
I will buy anything before Kenda or Cheng Shin...(sp)
Paid extra to get Heidenau tires for RX50mk, and Like them, but often you get very
few choices in odd-ball sizes... :urban:
I'd be riding now, but Nascar is on TV, and warmer days coming.
burnt_toast
CalvinB wrote:The Kenda one in that size is pretty good, really cheap, decent wear, good grip. The Hoop is pretty soft, more grippy, heavier casing, wear is slightly worse than the kenda, but pretty good still, only down side is price, but its not bad. The S1 is probably the best, but it's near impossible to get to seat using tubes as it only comes in tubeless in 10 inch.
Grippy and soft is def what I'm after. Hoops came in last night! They look pretty nice for some tiny tires lol
Not sure what you mean about the S1's not seating. Running a 3.5-10 S1 in rear on my black S, stock rim, tubed no problem. Have ran the same combo before on the red S up in the banner, along with a 3.0-10 S1 front, also tubed no problem
CalvinB
Post by CalvinB »
I tried so hard to get mine to seat with tubes, never could. Im glad you have had luck though.
'93 Yamaha Jog SOLD
benji
Post by benji »
I've had some luck seating tires w tubes by inflating them to about 20 psi then backing them down to about 5 or so, and carefully bouncing it around to even out the seat.
