Spree shock for very heavy rider
Sorry but the title is a little bit click bait. I'm buliding a razz with zuma engine. Long story short I noobed it up and made all my brackets using a stock spree shock. Turns out the stock spree spring rate is nowhere near what i need. Are there any shocks that have a much higher spring rate than the stock shock, but have the same eye to eye?
Re: Spree shock for very heavy rider
I think you can get an adjustable air shock for a ruckus, and that should work.
- burnt_toast
that sounds like $$$benji wrote:I think you can get an adjustable air shock for a ruckus, and that should work.
projects galore
EastCoastCB
Is the spree shock similar to a ch80? if so there are shocks out there that will work.
Hahaha, yes it is. I think like $100-200. It's not really worth it, but I'd like to have a bad * doppler air shock or some kinda remote reservoir racing shock just for the look haha.burnt_toast wrote:that sounds like $$$benji wrote:I think you can get an adjustable air shock for a ruckus, and that should work.
I think most shocks from other scooters will,just make sure the eyelets are the same size
Get this one! A Lil pricy tho...
http://scootertuning.ca/en/suspensions/ ... range.html
EastCoastCB
http://www.ebay.com/itm/11-280mm-Single ... Fu&vxp=mtr
http://www.ebay.com/itm/Red-w-Chrome-Re ... oB&vxp=mtr
I'm putting one of these on my Elite-
http://www.ebay.com/itm/GY6-50cc-Moped- ... Pv&vxp=mtr
Seems like a good deal for $50.
