'00 Elite SR Build
Meloshameless
Re: '00 Elite SR Build
Yup, i put my vac on the naruku, works fine.
2000 Honda SR (purple swurp)
corsa
naruku
polini vari 5.5 gram
zx trans
Yasuni C16
corsa
naruku
zx trans
Yasuni C16
Perfect, thanks. Again, don't have the scooter in front of me, is the vacuum the top or bottom spicket on the tank output?
2000 Elite SR
Malossi Cast, 24mm Polini (36/110), 9.8 gears, Naraku intake, PG long exhaust, 6k yellow Polini clutch springs, 5g roller weights. Top speed: 60mph
Meloshameless
Should be th bottom one. Its the smaller diameter hose. U can test by sucking on the hose if nothing comes out its gas. When u suck on the air line, gas should pour out of the other hose.
corsa
naruku
zx trans
Yasuni C16
corsa
naruku
zx trans
Yasuni C16
Perfect, thanks for the info, I'll be working on it tomorrow.
2000 Elite SR
Question on oil tank removal, does everyone going to big bore route completely remove the oil tank and pump. I have an oil plug, I'll be pre-mixing, what is the nipple for on too of the 24mm Polini? Another vacuum area? If I do remove the oil tank, will the low oil light forever be ok?
2000 Elite SR
You don't have to remove the oil bottle, just plug the line going to the oil pump. Then disconnect the oil level sensor wires - the light won't come on after that. There's no harm done to the system. I taped mine to prevent any risk of contact to a power source.Cmoped9 wrote:Question on oil tank removal, does everyone going to big bore route completely remove the oil tank and pump. I have an oil plug, I'll be pre-mixing, what is the nipple for on too of the 24mm Polini? Another vacuum area? If I do remove the oil tank, will the low oil light forever be ok?
The nipple on the 24 is probably for vac. line, or oil injection. If not using it for anything, be sure to plug it so you don't have an unwanted air injector......
Ya the nipple on the carb is plugged, I didn't know if it would be better the hook the vac line to the Naraku intake or the carb.
2000 Elite SR
I think it would be better to hook the vac. line up to the intake. Keep the carb nipple capped/plugged.
Will do, thank you.
2000 Elite SR
Got some more parts off, having issues with the oil plug, doesn't seen to be fitting correctly.
- image.jpg (169.64 KiB) Viewed 9571 times
2000 Elite SR
Maybe the oil pump o-ring is still stuck in there??? Pull it out and visual inspect.
Nope, I've got the old O-ring out, seems like it's just a touch too big for some reason.
2000 Elite SR
That's how mine fits...
I don't think it's supposed to be flush.
Hmmm. Maybe there is something in the bottom hole? You may have to modify it at the tip???
Mine have all fit flush.
Really? I never got instructions or anything w mine so i figured it was supposed to be like that.
