'00 Elite SR Build
Meloshameless
Re: '00 Elite SR Build
A good baseline is a difference of 70, so if main is 108 run a 38 pilot, mine is 110 and 40. But if it runs then great, keep it rich while u do heat cycles. Start bike let it idle until it reaches running temp, 140-170, then shut off and let cool completely. Do that 10 times before riding. After that run at least half tank without going into full throttle and never hold throttle in same position for elongated periods of time. Basically constantly brap brap while riding. That should break bore and rings in nicely and seat rings proper for longevity.
2000 Honda SR (purple swurp)
corsa
naruku
polini vari 5.5 gram
zx trans
Yasuni C16
corsa
naruku
zx trans
Yasuni C16
If your not reusing the reed block, you can grab it w pliers in the center or jam a screwdriver threw the petals to try n pry it off (what I did)
Meloshameless
Judging by the pic above he already got old one out and put new naruku on...
corsa
naruku
zx trans
Yasuni C16
corsa
naruku
zx trans
Yasuni C16
Ya ill have to fiddle with the jetting after it's broke in. It's idling great. I've gone through the break in process many a time, I'll give it it's time before I open it up. Ya, I put the Naraku intake on, not using the stock one anymore.
2000 Elite SR
Malossi Cast, 24mm Polini (36/110), 9.8 gears, Naraku intake, PG long exhaust, 6k yellow Polini clutch springs, 5g roller weights. Top speed: 60mph
Went out for my first slow ride today after heat cycling it quite a few times. For the first couple mph's it's pretty slow on take off, it gets pretty peppy around 1/4 throttle and 10mph. Anything past about half throttle feels pretty dead as well. I believe the pilot and main and pretty fat right now, I'm running a 108 main and 45 pilot. I think I'll try 40/106 after it's broken in a little more.
2000 Elite SR
Ya it's only 40 degrees here today, once it gets warmer I'll have to lean it out more. The clutch engaged around 4500ish RPM's, I think the spring in the clutch are 1.5k? It something like that, I'll need some stiffer ones.
2000 Elite SR
Put more time on the scooter today, re jetted it to 40/106 still seems pretty rich, but is definitely better than before. My temperature gauge sensor broke, plus it was still leaking out onto the head because the sensor ring isn't a perfect circle. Causes an issues without the crush washer on the spark plug being there anymore.
- image.jpg (97.43 KiB) Viewed 12104 times
2000 Elite SR
Have put nearly 80 miles on the big bore kit, needs to be leaned out a bit. Running 40/106 in my 24mm Polini carb. Has 9.8 gears, does 60mph on the GPS, gets up and goes really well. Very happy with it.
- image.jpg (128.68 KiB) Viewed 12078 times
- image.jpg (104.22 KiB) Viewed 12085 times
2000 Elite SR
Very nice ride! Super clean. Looks perfect! What kind of oil are you using?
It's very very clean, only 2000 miles on it. I'm using Yamalube oil in the premix, It's what I use in my motocross race bike, it's not the cleanest burning, but it does a good job. Mix it at 30:1
2000 Elite SR
I've got about 300 miles on the Malossi kit now, fun little scooter with the 9.8 gears in it, rips from a dead stop, does wheelies everytime I crack the throttle. With the gears I only get about 57ish mph for a top speed on flat ground, which is all I need. I think i have a slight air leak somewhere though, since I'm running a 110 main, it was running decent with a 106, then I took the exhaust off and put it back on. I think I tightened it down too much and possibly have a leak right there, the head pipe might've flexed a little. Other than that the cylinder should be pretty sealed, I coated all the gaskets when I installed it. I'll have to figure something out, but overall the scoot runs great.
2000 Elite SR
wow man props on the purp! super clean!
I only dreamed about a purple sr, then one popped up in craigslist for cheap with 600 miles and I grabbed it that day. It's mint, not a scratch on it.
2000 Elite SR
- Rip_City_Spree
Are your running a tach? Curious what Rpms your hitting with your pipe? I will be taking my busted up Corsa off here soon and basically running an identical setup. What are your roller weights? And what springs are you running in your clutch. Great looking bike by the way.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
Naraku sport variator
Currently 5g rollers
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
Awesome build!
Currently own:
->1995 Honda Elite 50 (Derestricted)
Have previously owned:
->Multiple 94-01 Elite 50s
->1985 and 1986 Honda Sprees
->1985 Honda Aero 50
