back firing
back firing
When I hit around 50 - 60 MPH bike starts to back fire. Could that be my main jet?
Re: back firing
When my bike hit 50-60mph it back fires
Could it be my main jet or could it be my float in my carb.
What causes backfire anyway
Re: back firing
I had popping sounds when my reeds were goin out, but google search carb tuning, i wanna say backfire falls under rich condition but cant remember.
2000 Honda SR (purple swurp)
corsa
naruku
polini vari 5.5 gram
zx trans
Yasuni C16
corsa
naruku
zx trans
Yasuni C16
Re: back firing
The after fire, popping can be a LEAN condition or if it is truly backfiring through the carb it is RICH.
2021 DRZ400sm
2021 DRZ400sm
Re: back firing
Its backfiring from the exhaust
Re: back firing
This was explained to me by grizzled Sportster Cognscenti years ago. Under compression, the inhaled mixture is non-combustibly LEAN for several piston strokes. The fuel and air is wasted out the pipe until enough gathers in a of the header segment. After a certain number of cycles, the mass ignites at once producing the BANG!!
