72cc Rebuild
Justinmarldizah
72cc Rebuild
Post by Justinmarldizah »
Rebuilding my moto
Dd50 block ported
Stock crank, 1500 center springs and yellow clutch springs, sef ramp, kelly pulley, runnin 6.5 and 7 weights, rrgs pipe, big teeth belt, corsa ported. Only runnin one metal gasket and a head gasket.
Any suggestions? Looking for top end. Should i put 2000 center springs?
Meloshameless
Re: 72cc Rebuild
Post by Meloshameless »
Head gasket? I used the metal gasket on the bottom and green rubber ring for the head, basically stuff that came in the corsa kit. No need to use anything extra on the head with a stock crank. That'll lower ur compression.
2000 Honda SR (purple swurp)
corsa
naruku
polini vari 5.5 gram
zx trans
Yasuni C16
Re: 72cc Rebuild
The first thing I do after assembling a block is to measure compression. 140PSI can survive pump Premium fuel. Much more and you need higher octane.
The next thing to do is to perform a check of all the gasket seals with soapy water, looking for bubbles.
