Variator/ drive face holding tool, any interest?
Chicago Ben
Post by Chicago Ben »
I'm just going to throw this out there
Would any of you guys be interested in a drive face holding tool? I want to see what kind of pricing a CNC shop can give us if we get say... 5-10+ interested in this
Thanks
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
1000k Polini triples
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Meloshameless
Re: Variator/ drive face holding tool, any interest?
Post by Meloshameless »
I use a cordless impact gun to get mine off, so never had a problem holding drive face or getting nut off, so personally no interest, not sure what others think...
2000 Honda SR (purple swurp)
corsa
naruku
polini vari 5.5 gram
zx trans
Yasuni C16
cruzingratiot
Post by cruzingratiot »
I use these
if you have a welder and a old pair of vice grips just make them
http://www.motorcycle-superstore.com/48 ... 6&device=c
Donate Life
http://www.donatelife.net/
Thank You
Chicago Ben
yup i have a tusk clutch holder as well
Was just gauging interest as this would be a nicer solution
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
Rip_City_Spree
Post by Rip_City_Spree »
Harbor freight locking oil filter wrench. Opens just wide enough.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
Naraku sport variator
Currently 5g rollers
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
bonesv
Post by bonesv »
That's a good tool to have if it is easy to use and not expensive. Personally, I don't believe in using "power tools" to install nuts and bolts on aluminum, or expensive engine parts. Removing them is one thing but risking damage is not worth the time saved. Good job Ben. I'm down for finding out how much it would actually cost.
Kustomkarma
Post by Kustomkarma »
It looks like a good idea, but the cost would be a big deciding factor for me.
I have no clue how your design works... :confused:
If those teeth are supposed to engage the fins in the variator, not liking that idea.
whitey
Post by whitey »
If your going to make something like that put a handle on it and probably half circle of teeth. Then you don't have to bolt the tool to the case you just hold the special wrench in one hand and your ratchet in the other.
78 Honda Hobbit Athena
81 Puch ZA50 Polini
71 CT70 Blue
79 Z50 Red
