My First Spree Swap (Aero NH125)
Ultraliner
Re: My First Spree Swap (Aero NH125)
Wow that is one clean paint job Tyler, very nice! Any trade secrets you have i'm all ears
Thanks, the ebay ad didn't say what cc this pipe is for. It does look similar size expansion chamber to other 125cc pipes but hard to tell unless we could see them side by side. It's experimental so I went cheap, not many people mess with the exhaust on the nh125.1man8scoots wrote:Is it a 125 pipe? Freaking sweet build. Spaero 125!
Thanks for the compliment, rattle can paint can only look so good. Plastic is my least favorite thing to paint, metal is way easier.Ultraliner wrote:Wow that is one clean paint job Tyler, very nice! Any trade secrets you have i'm all ears
1man8scoots
So they're at a different clocking degree? Looks like the same degree the Yamaha vert is. I have a few yamaha vert pipes laying around if you're interested in trying one. You pay shipping. I have one that is very similar to the one you're using but for vert mina.
Thanks for the offer, I'm just going to try out the pipe I have now. I still have my stock nh125 exhaust if the dio pipe doesn't work out.1man8scoots wrote:So they're at a different clocking degree? Looks like the same degree the Yamaha vert is. I have a few yamaha vert pipes laying around if you're interested in trying one. You pay shipping. I have one that is very similar to the one you're using but for vert mina.
I messed around with the pipe mounting and got it closer to the engine. I've been on a couple test rides and it runs pretty good, unfortunately the pipe will scrape on the ground if I lean into right turns too hard. No wonder the stock nh125 header pipe goes across the fan cover, rather than under it.
nice work. It looks Cool
Great color choice AND spray-job...
Like the pipe too..good luck with it...mm...
ped wrote:nice work. It looks Cool
Thanks Guys!motormike wrote:Great color choice AND spray-job...![]()
Like the pipe too..good luck with it...mm...![]()
- Xxbeejay45xx
Wow very unique build sir! One of a kind! Great job looks great! It's a keeper!
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
Polini vari, clutch, springs
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Front and Rear disc brakes
Dio Live headset
Stretch and fatty rear wheel
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
Thanks man.Xxbeejay45xx wrote:Wow very unique build sir! One of a kind! Great job looks great! It's a keeper!
Upgrading the clutch springs on my nh125, No companies make springs specific to this engine but I found a common size. I'm using 2000rpm yamaha jog springs, it improved the take off but wish I could get higher than 2k springs. Maybe I'll try drilling a hole in each clutch shoe to lighten, also going to experiment with upgrading the center contra spring.
