121 cc jets size questions??
Peteyparado
Post by Peteyparado »
Old set up 30mm OKO with ct mani.. 150mj 52pilot..
New set up 30mm polini with naraku mani 140mj 42 pilot.
I've been told by a lot of people that a polini is way more efficient than a thirsty OKO..
But with the 140mj an the 43 pilot is seems to be running rich motor still sputters at less than or around 1/4 throttle.. I'm scared to go leaner.. Any1 else running 120cc with a polini... What's your jet size..
86 aero af16 swap. 121cc water cool.
Polini 30mm carb
Naraku mani
Scorpion stroker pipe
Stage6 CDI
5gram rollers
Keli high speed Variator
6.1 gears
94mph
Peteyparado
Re: 121 cc jets size questions??
I just looked at the plug an yes it's still soaked.. I try to look for the Richard guy for u Brandon..anyway I try go lower on the jets an c what I come up with..
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
Hppowdercoatings
Post by Hppowdercoatings »
Right now I'm still a little on the Fat side on my 120cc, and I'm running a 32mm Polini but I'm at
138/40 on Jetting...
Peteyparado
Oh dam I'm at 138mj an 42 pilot..on a 30 polini I think 136 is perfect for me...
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
