Easy motor swaps for SB50P?
85stroka
Post by 85stroka »
DO3 wrote:I was surfing and found a VIN listing for Honda scooters and they had the 87 Aero listed as AF09E, was there anything special about that motor or just a typo?
My second question would be about the transmissions, I assume all the AF05E trannys are like mine, the AF16E are adjustable but what about the late 80's Aeros?
Thanks again for the help guys.
yeah,I think I got that mixed up, AF O9 e is the 87 and aero blocks ,af05 is the eve smile in japan :D
Remember,everyone is human,even if there stupid!
Skullet
Post by Skullet »
noiseguy wrote:
maddog wrote:Look for a 94 and up elite-s engine!
That would be the best. Next is '87-93 Elite, then Aero 85-86 Aero.
what about an elite 125? or an elite 250? thats the one i really wanna do.. mount a radiator in front and be haulin butt around illinois... ive read reviews of the elite 250 that say it hit 70+... or the other thing i was thinkin of would be to use the engine and 4-spd tranny from a honda cr250 dirtbike. 2-stroke, multiple speeds... sound good?
hrnytrtlsgsxr
Post by hrnytrtlsgsxr »
if you want two storke with no modification you can try and find an aero 80. the earlier moels were two stroke so that would be two-stroke 80cc stock, no modification necessary.
Skullet
Post by Skullet »
yeah, i used to have one, but it got stolen. :( what i want to know though, is how MUCH modification would be required to fit a 250 in the elite? everything ive read says that the elite frame is the same from the 50 all the way to the 250, so im thinkin another honda 250 SHOULD fit. if not tho, i have a welder and a bunch of air tools...
85stroka
Post by 85stroka »
Skullet wrote:yeah, i used to have one, but it got stolen. :( what i want to know though, is how MUCH modification would be required to fit a 250 in the elite? everything ive read says that the elite frame is the same from the 50 all the way to the 250, so im thinkin another honda 250 SHOULD fit. if not tho, i have a welder and a bunch of air tools...
All your info of all elites being the same is way wrong, all the elites are different from 50 -250,frame size etc
Skullet
Post by Skullet »
no crap? damit.. so how different are they?
85stroka
Post by 85stroka »
not even close,
MySpree
Post by MySpree »
imagine a ball then a square, then a triangle... thats how same they are
85stroka
Post by 85stroka »
MySpree wrote:imagine a ball then a square, then a triangle... thats how same they are
that's funny, about the only thing they share are common bolt size's 8-10-12-14mm and the name "elite" cant forget about the "0" they alll have that :D
Skullet
Post by Skullet »
lol... that bad huh... hmmm... so does anybody know a ballpark figure speed-wise if i spend say... ~$500 on this thing? i WANT it to go around 60 or so with me and my g/f on it (both ~120-130 pounds)
I always thought a 250 Elite motor would make a screamer out of an Elite 50... it would be freakish looking though.
Seriously... besides all the welding and plumbing required, you'd need to hack away most of the sidepanels and you'd still have mismatched wheels (10" and 12".) It would be ugly, probably handle like crap, and have inadequate brakes. And for $500, you could buy a motorcycle that would haul you both safely. Or find a running Elite 250.
At 120# apiece, an Elite 50 (94+) could be modded to carry you both up to 60 MPH... but I wouldn't do it. It would safely carry both of you as is.
MySpree
Post by MySpree »
im trying to trade a dio eing right now for a psp, get me a psp and the engine is yours.
darat
Post by darat »
i was thinking about putting my elite 150 on my spree..
hagstrbh
Post by hagstrbh »
This post was stretching, so I also started another, but I'm having Elite SE50(P) issues and I'm wondering what my options are.... my needs are simple, but maybe no less difficult to achieve -- I'd just like to break the 30mph mark! But without doing any "serious" mods to the bike. I'm thinking a new pipe is in my future...
BTW, thanks for the directions to Sports Wheels! The guys at Honda Town (Lake St., Minneapolis) knew of it, but couldn't really direct me. Don't worry though, I won't be able to get there for a couple weeks. :D
1987 Elite SE50P
gingerbreadman
Post by gingerbreadman »
you will most likely need a bore/carb setup before you put on a aftermarket pipe.
catch me if you can (",)
