2000 Japan Jog
Peteyparado
Re: 2000 Japan Jog
89 Honda sb-50 u know we can register those bikes as mopeds in Hawaii or is motorcycle ?
86 aero af16 swap. 121cc water cool.
Polini 30mm carb
Naraku mani
Scorpion stroker pipe
Stage6 CDI
5gram rollers
Keli high speed Variator
6.1 gears
94mph
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
Re: 2000 Japan Jog
you will need to call the dmv kapahulu. to verify vin number.
vin number vary weather moped or scooter.
scooter registered need to have safety check, insurance and hawaii plate, can go on freeway.
Re: 2000 Japan Jog
I'm running these oil now.
Good oil- castor full synthetic.
- 2016-07-08 23.02.20.jpg (96.82 KiB) Viewed 26670 times
Re: 2000 Japan Jog
You can look this up: Castrol got its name from the castor bean, whose oil was extracted - literally - from that legume. It can't be both Castor and "Full" synthetic. It's a blend.
shotcaller
Re: 2000 Japan Jog
True!Whellman wrote:You can look this up: Castrol got its name from the castor bean, whose oil was extracted
Some claim similar fame for the Pinto as the only auto named after a bean.
Good looking Jog there
Re: 2000 Japan Jog
the silkolene kr2 oil is not avaliable in the usa... just in from england.
Re: 2000 Japan Jog
What front fork do you have? Is that a jdm jog fork?
Re: 2000 Japan Jog
yes it isbenji wrote:What front fork do you have? Is that a jdm jog fork?
2000 Japan Jog
Hey sorry, managed to get a photo been flat out
but thats it, in the airbox, not sure what it is or what it does
Thanks
Thanks
