crank bearings
dbkawasaki
crank bearings
whats a good crank bearing for af16? aftermarket or oem? thanks
Re: crank bearings
Honda's own NTK bearings are hard to beat. At $16 or so apiece, it's not worth risking your engine on something else.
dbkawasaki
Re: crank bearings
cool thats the kind of response i was looking for, thank you
dbkawasaki
Re: crank bearings
ok looks like they are in stock, the s6 anyway..ill order those instead...thabks for that heads up!graphite9 wrote:I run polini evo, or stage6 SKF, just cause I don't want to change them prematurely.
beware, alot of the NTK now is out of tiawan, not true japan like most honda bearings. Joe let me in on this.
