Last night I installed the 48mm BBK from Taz (runnning beautifully finally
Can I temporarily install and momentary button as a start button? should I install a three way toggle in place of the killswitch? should I install another three way toggle in place of the ignition switch?
If I am on to something with the questions I've listed above would somebody be kind enough to explain the process simply? ex: connect X wire to one side of switch and X wire to other side
Thank you all in advance for all the help. I believe we are in the final stages of getting the scoot back on the road and this would not be without you guys.
