In this next video, you will see a LEAN ON OIL condition. This is the BBK being ran with 100% fuel in the tank and just the pump providing lubrication. I want you to compare stoich values here as well, and you'll get a longer, closer look at where I drilled the holes. In this run we both expected the bike to need lubrication, better be safe then sorry, so for WOT attempts... forget it, we are just testing values through different comfortable ranges that won't heat things up too much. Now when you compare THIS run, to the other video with the same 3 holes but with 128:1 in the tank, you can see in the stoich, how much adding that bit of extra lubrication helps the stoich. If the pump, by some oddball chance, is doing 32:1, then what is being fed to the BBK at MAX, is 40:1
So for anybody keeping score and wanna delete the pump and do premix, the most safest, reasonable range that seems to work, is 40:1. The most oil you wanna premix, might very well indeed be 32:1 though. Here is my evidence.. I went 64:1 in the tank first round and saturated out. If the pump was running 32:1 at that point, I was in fact, running at 24:1 oil. I had only ASSUMED at that point that the pump will put out a range of 70:1-50:1. The math on that works out pretty good if the pump does 70, but if it actually does more, then you can saturate real quick with an added 64:1
But anyways.. I think this video does answer the question of can the BBK be ran on just gas? At this point, I want to give that a resounding NO! Stoich changes alone should tell you that you need more lubrication at this point when the 2 videos are compared.
The video with 3 holes and extra oil gives us all around best stoich with that extra lubrication.
Here is what it gets you without the extra lubrication:
https://www.youtube.com/watch?v=0bAQYmBILOE
