Picked Up A 2001 Elite Today!
Re: Picked Up A 2001 Elite Today!
So I'm topping out with the arrow same as before, 4100 rpm. Just a lot better acceleration. I dropped my weights to 33g from 41g and picked up 500rpm on the top end. What am I doing wrong here? Shouldn't I be closer to 8k red line?
1985 Spree AF16: viewtopic.php?f=20&t=31053
2001 Elite Daily: viewtopic.php?f=16&t=31397&p=272223#p272223
- Rip_City_Spree
I would think you should be higher. But running a stock clutch and carb might be hindering you. I could be wrong but you should getting higher Rpms with that pipe. How is it running? Top speed
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
Naraku sport variator
Currently 5g rollers
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
I haven't done a top speed run but it feels like it would taper out a bit earlier cause of the lighter weights. It runs great though.
I thought maybe if it was a carb issue my temps would be skyrocket.
Maybe the tach isn't accurate? Seems to be right at idle. It reads 1200 rpms.
Stock contra and yellow clutch springs. Should I try blue or white contra?graphite9 wrote:what center spring? Also stock cltuch springs? If you dont have a stiff center spring it will destory every aspect of the power delivery. I had a bad spring inthe rear and my bike was an absolute dog.
- Rip_City_Spree
I would try different contras for sure. trial and error is your best guide. Do 1 thing at a time as even though I've been tuning my bike for quite awhile it still boggles my mind how it all works. I just try things until I come up with the best output.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
