Anyone try Aero 80 reeds in an Af05? Results??
Meatball
Post by Meatball »
Was reading about it from a post from Bear in another forum....cant find any info where someone tried in a Stock Af05e...in this thread, Bear says its fits!
http://motorscooterguide.net/Forum/view ... ?f=3&t=965
eclark5483
Re: Anyone try Aero 80 reeds in an Af05? Results??
Post by eclark5483 »
Been wanting to try some SB50 reeds myself. I got someone doing a port job on my intake, would love better reeds to go with it, but haven't found any yet.
bonesv
Post by bonesv »
They don't fit on af16 directly. The reed block is configured a little differently. If you made a riser/spacer for it then it would fit. I've already done this but if you want the parts I have them. PM me
Meatball
Post by Meatball »
Before I go swapping reeds Id like to hear from someone who has done it. From that post from Bear, he says "this Aero 80 reed cage will also fit the AF05E engines with the 4 bolt intake. It will not fit the AF05E Spree(NQ50), Elite E (SB50) or the 1985 Aero 50 (NB50M) which all have a 2 bolt intake." So youre saying it needs a spacer to fit my AF05E with a 4-bolt?
bonesv
Post by bonesv »
Meatball wrote:Before I go swapping reeds Id like to hear from someone who has done it. From that post from Bear, he says "this Aero 80 reed cage will also fit the AF05E engines with the 4 bolt intake. It will not fit the AF05E Spree(NQ50), Elite E (SB50) or the 1985 Aero 50 (NB50M) which all have a 2 bolt intake." So youre saying it needs a spacer to fit my AF05E with a 4-bolt?
viewtopic.php?f=3&t=31148 It's just my experience but you are welcome to try it yourself.
patthesoundguy
Post by patthesoundguy »
I think G9 has the spacers you seek, or at least he used to.
benji
Post by benji »
I think you can get an aftermarket reed cage for fairly cheap, or make your own carbon reeds from a reed sheet. If you can find a reed block from a dj1 w the af05 it'll have a 3-reed block.
benji
Post by benji »
http://www.racingplanetusa.com/reed-val ... _MQnHTn_qA http://www.racingplanetusa.com/reed-val ... _MQeHTn_qA http://www.racingplanetusa.com/reed-val ... _MQSHTn_qA
All these should fit and work well w/o adapters. You can also get a malossi reed block, but it's like $80 and for that much you can almost get a nice big valve intake with a kx65-style v-shaped 4 petal or 6 petal reed block, but for that you'd need the intake adapter plate sss sells, like this one
http://scooterswapshop.com/collections/ ... ld-adapter
