My new Dio
- BigWillieStyles
- BMX
- hrnytrtlsgsxr
- hrnytrtlsgsxr
Dude you want to say somthing let's meet up , I'll show you some b.smaddog wrote:tell us some more b.s. stroka, just like the idiot cops that dump there bikes in front of the President! the ultimate morons live hereyou guys should crawl under this rock
Remember,everyone is human,even if there stupid!
- hrnytrtlsgsxr
here you go dumb *maddog wrote:tell us some more b.s. stroka, just like the idiot cops that dump there bikes in front of the President! the ultimate morons live hereyou guys should crawl under this rock
this is the whole rear pulley set up that came off a dio fit motor(af18)
here is the motor in the center that 03xrs brought in for me from japan. It's the one in the middle with the shroud
godd d*** you are always wrong.
OOPS some one put their foot in their mouth yet again!, d*** your stupid ,you say all this stuff, yet cant and wont be able to back anything up other then your a arrogant stupid *.just shut up and leavehrnytrtlsgsxr wrote:here you go dumb *maddog wrote:tell us some more b.s. stroka, just like the idiot cops that dump there bikes in front of the President! the ultimate morons live hereyou guys should crawl under this rock
godd d*** you are always wrong.![]()
- hrnytrtlsgsxr
- BigWillieStyles
- BMX
- BigWillieStyles
- BMX
ok well from this Japanese site, if you look down at clutch which reads
クラッチ形式 - it says there all the same right?
Babelfish - Dry multiple plate shoe systems
http://www.honda.co.jp/news/1999/2990913.html
Dio Mods:
Zero Racing Exhaust
Hi Speed Pulley
Heavier Rollers
Posh CDi
Pod filter
Zero Racing Exhaust
Hi Speed Pulley
Heavier Rollers
Posh CDi
Pod filter
- hrnytrtlsgsxr
I would change the rear pulley and clutch. The clutch on the dio fit is held on to the rear pulley with a c-clip and not a threaded nut like other dios have.BigWillieStyles wrote:ok well from this Japanese site, if you look down at clutch which reads
- BigWillieStyles
- BMX
- hrnytrtlsgsxr
the pulleys can be after market or stock but they are basically the same which uses a threaded nut to hold the clutch in. It's the clutch whether stock or aftermarket where the shoe springs can be changed.BigWillieStyles wrote:ok i will have a look at this next week on my day off. Do they make aftermarket rear pulleys?
C-clip? please explain? Does this mean its easier?
the pic on the left is a stock rear pulley. the one on the right is the stock rear pulley from the dio fit and actually the dio fit pulley looks alot larger like a zx rear pulley.
