My new Dio
BigWillieStyles
Post by BigWillieStyles »
hey thanks did you use babel fish or something? Some great info but does it say wat type of clutch it has?
Dio Mods:
Zero Racing Exhaust
Hi Speed Pulley
Heavier Rollers
Posh CDi
Pod filter
85stroka
Post by 85stroka »
nope babble fish sucks, there better stuff out there,and no it does not say what type of clutch, have you gone only to one shop or have you tried others and they say the same thing?
Remember,everyone is human,even if there stupid!
hrnytrtlsgsxr
Post by hrnytrtlsgsxr »
maybe your clutch is like the clutch on a dio fit. It has an af18 motor but has a different clutch.You can change the clutch to an after market one.
85stroka
Post by 85stroka »
hrnytrtlsgsxr wrote:maybe your clutch is like the clutch on a dio fit. It has an af18 motor but has a different clutch.You can change the clutch to an after market one.
Yeah what does the clutch bell look on that motor you got from me?
hrnytrtlsgsxr
the clutch and rear pulley is different thinking about it so you might as well change the whole rear pulley set up
maddog
Post by maddog »
tell us some more b.s. stroka, just like the idiot cops that dump there bikes in front of the President! the ultimate morons live here :lol: you guys should crawl under this rock :wink:
85stroka
Post by 85stroka »
maddog wrote:tell us some more b.s. stroka, just like the idiot cops that dump there bikes in front of the President! the ultimate morons live here :lol: you guys should crawl under this rock :wink:
Dude you want to say somthing let's meet up , I'll show you some b.s :shock:
hrnytrtlsgsxr
here you go dumb *
this is the whole rear pulley set up that came off a dio fit motor(af18)
here is the motor in the center that 03xrs brought in for me from japan. It's the one in the middle with the shroud
godd d*** you are always wrong. :roll: :roll: :roll: :roll: :roll: :roll:
85stroka
Post by 85stroka »
here you go dumb *
OOPS some one put their foot in their mouth yet again!, d*** your stupid ,you say all this stuff, yet cant and wont be able to back anything up other then your a arrogant stupid *.just shut up and leave
hrnytrtlsgsxr
yeah madchihuahua's a dumbarse. i don't say shet unless i can back it up. With pictures none the less. :roll:
BigWillieStyles
guys you can find another thread to hollow at each other at,
thanks guys so can i just change the clutch or does it require the removal of the rear pulley and replacement.
Dio Mods:
Zero Racing Exhaust
Hi Speed Pulley
Heavier Rollers
Posh CDi
Pod filter
BigWillieStyles
ok well from this Japanese site, if you look down at clutch which reads
クラッチ形式 - it says there all the same right?
Babelfish - Dry multiple plate shoe systems
http://www.honda.co.jp/news/1999/2990913.html
Dio Mods:
Zero Racing Exhaust
Hi Speed Pulley
Heavier Rollers
Posh CDi
Pod filter
hrnytrtlsgsxr
BigWillieStyles wrote:ok well from this Japanese site, if you look down at clutch which reads
I would change the rear pulley and clutch. The clutch on the dio fit is held on to the rear pulley with a c-clip and not a threaded nut like other dios have.
BigWillieStyles
ok i will have a look at this next week on my day off. Do they make aftermarket rear pulleys?
C-clip? please explain? Does this mean its easier?
Dio Mods:
Zero Racing Exhaust
Hi Speed Pulley
Heavier Rollers
Posh CDi
Pod filter
hrnytrtlsgsxr
BigWillieStyles wrote:ok i will have a look at this next week on my day off. Do they make aftermarket rear pulleys?
the pulleys can be after market or stock but they are basically the same which uses a threaded nut to hold the clutch in. It's the clutch whether stock or aftermarket where the shoe springs can be changed.
the pic on the left is a stock rear pulley. the one on the right is the stock rear pulley from the dio fit and actually the dio fit pulley looks alot larger like a zx rear pulley.
