Wanted to see what people are using in conjunction with the PG Short
-Exhaust: PG Short
-Cylinder:
-Carb/ intake manifold:
-Variator:
-Contra spring rate/ brand/ color:
-Final gear set:
And of course, comments on your PG Short setup/ performance/ observations are welcome as well.
Thanks everyone!
PG Short users, what's your setup?
'92 Super Dio ZX - AF18 Corsa
Re: PG Short users, what's your setup?
Pg short
Taz land 50mm bore
Ct with 23mm cp polini
Keli almost to the brim.tuned well
Blue contra, blue triplets polini
9:1 gearing
Pops wheelies like no ones business, scary, no speedo so cant tell you. Is on a spree frame. Drum breaks just fade.
Taz land 50mm bore
9:1 gearing
2021 DRZ400sm
2021 DRZ400sm
Flash 3.26 had a Corsa cylinder, a black OKO 26mm carb with a ported OKO CT Chrome intake, a big Malossi (?) 97mm variator, a thick Tai contra spring pushing a Kymco-brand ZX rear pulley. I found the Short to make really good power at a reasonably low RPM, like 10,400. It had good (for a Corsa) take-off, even with 7.57:1 secondaries, and I saw over 71MPH, albeit with a fair tailwind at that RPM. That said, you can't really buy a pipe and build a scooter around it. But for the money I found the Short to be a durable -unlike the Long - and good-performing option.
