batterys?
myhonda
batterys?
Post by myhonda »
is it possible to hook up 2 batterys but have one run the lights and normal scooters operations and the other one specific for the extra stuff like sterio and stuff so it will still have enuph power for the lights even if the radio is draining batt 2?
MySpree
Post by MySpree »
my elite had the power to run music and fog lights, neons and run everything.
myhonda
Post by myhonda »
for me my battery slowly dies at night whan i got the radio on. it keeps killing my batters so i havent had the radio on recently
Farfignugin
Post by Farfignugin »
if you can fit the two batteries on it, then you could run them in PARALLEL (not series, otherwise you would kill stuff) aka: split negative wire, and run one to each battery on the negative terminal, and split the positive and run each to the positive terminal on the battery.
but then you might need to get a bigger charging system (maybe). not sure.
antoniobustamante
Post by antoniobustamante »
Why couldn't you just run a bigger motorcycle battery. wouldn't that use less space than two ped batts. where could a person get a bigger charging system say for a spree.
1992 Ford F250, 2001 Yamaha Grizzly, 2004 GSXR 1000, 1986 Honda Spree
myhonda
Post by myhonda »
this is what i wanna do. please exuse the crapy drawing i suck at paint i wanna take the original wires that charge the batt and split them having one batt for the scoot and other for electronics like this an would this work like im saying it?
veloc1ty
Post by veloc1ty »
wire a on/off switch in between the radio and battery, or yes, hook them in parallel
Farfignugin
looks like you got it right, but I doubt that you could separate them between the two things without doing some excessive rewiring.
MySpree
Post by MySpree »
you could just add a wire from pos to pos nad neg to neg
