Recommendations needed for intake on 50mm af16e
Re: Recommendations needed for intake on 50mm af16e
Imo, not lately. Stage6 has seem to fallen off lately from what I hear. And naruku is an "affordable" brand. There not exactly high quality race parts, but I don't think there low quality stuff either. But I wouldn't pay a premuim for it.
The intake is just a hunk of aluminum. What ever one you buy will most likely benefit from new reeds and some grinding/clearancing/sanding/porting,etc. I really don't know tho, I've only bought cheap Taiwanese intakes like the ct. Haven't had any problems yet.
CT manifolds waste fuel?
No problem, no I didn't see a note anywhere in my end.
I don't mind buying a polini carb, I don't know which size would suit my bike better, 24 or 28. I have no idea what range Jets to start with. I understand carburetor theory I just don't know where to start with this bike or the best place to acquire the parts.
Why is upgrading the reeds so critical at this stage?
Get a 21mm cp, stage 6 intake and a pg short
That is what i wished I did the first time.
Now if you want to get adventurous and go all out polini corsa and a corsa pipe with a 21mm cp, stage 6 intake, and 9:1 gearing. Wpuld be a soild bike with a good vari and clutch too.
The 50mm bore in my case only seized and had issues to begine with. Wanst very happy with it, but I wont fault the seller some people have great luck with them.
2021 DRZ400sm
2021 DRZ400sm
I have a pg for sale if you need one. 100 or short 125 or long
I have a video of mine that SHATTERED. Caught it before it ate itgraphite9 wrote:the 24 will be best on the 50mm. If you do the ct manifold you need to sand down and true every flat surface because they do leak. The cages are brittle, and they shatter. I've heard of and seen it happen to probably 12 people a year. The plastic, metal and reeds go into your engine.
2021 DRZ400sm
2021 DRZ400sm
No question about Graphie's 3/11/17 post; the Polini carbs don't Look a lot different from the OKOs, but they sure do Run better. Totally worth the coin not to have dodgy jetting and spring leaks a year down the road. Quality control is important, Who Knew? The Italians did.
U get what u pay for. Naraku and stage 6 are both way better. There bolt on peice of mind, no modding needed. The c/t is less, but u have to sand and still just hope it seals and ur reeds dont explode ruining ur bore, possibly crank, maybe blow a hole in ur case. Just not worth the risk over $40-$50....
2000 Honda SR (purple swurp)
corsa
naruku
polini vari 5.5 gram
zx trans
Yasuni C16
corsa
naruku
zx trans
Yasuni C16
I don't mind paying for the polini carb, where is the best place to get a 24mm Polini carb and intake and Jets?
Here's where I get my Polini parts, along with other nice thingsAwdunman wrote:I don't mind paying for the polini carb, where is the best place to get a 24mm Polini carb and intake and Jets?
https://scooterswapshop.com/
