Does anyone know where I can get some new good parts? A rebuild kit for this would be great, but I doubt it's available. Any help is greatly appreciated!
Spree Transmission Rebuild Kit?
I recently found out that my 86 Spree needs a transmission rebuild. The bearings are shot, and when you spin the rear tire on the stand, you can feel resistance, (and no it's not the tire scrapping the cement). I wanted to check the oil in the case, I unscrew the drain bolt and black oil comes out
I know that isn't right, and you could kinda see a "metallic look" in the oil. Obviously I need new bearings installed, I checked partzilla for the parts and the case bearing and gasket is all obsolete.
Re: Spree Transmission Rebuild Kit?
Don't you have like 40 spares laying around?
I was able to source a few Spree bearings directly from my local Honda dealer. I had the part numbers with me when I went in and chatted with the guy. The bearing(s) you need have changed part numbers over the years but its still the same bearing. When he looked on his computer, it showed part#91028-GF0-005 had changed to ?????-???-???. However, the NEW part# was also discontinued and had changed yet again to a NEWER number. I think he had to trace it back to 3-4 part#'s before he figured out that they still make it and its currently being used on a different bike.....same bearing tho.
Thanks Meatball! This is some very useful information, I'm sure that same bearing is being used still, so now I just gotta find it.Meatball wrote:I was able to source a few Spree bearings directly from my local Honda dealer. I had the part numbers with me when I went in and chatted with the guy. The bearing(s) you need have changed part numbers over the years but its still the same bearing. When he looked on his computer, it showed part#91028-GF0-005 had changed to ?????-???-???. However, the NEW part# was also discontinued and had changed yet again to a NEWER number. I think he had to trace it back to 3-4 part#'s before he figured out that they still make it and its currently being used on a different bike.....same bearing tho.
Get a new oil seal also for the inner bearing nearest the tire. If you don't have one on hand when you remove the old one, it will rip for sure. I bet if you have a new one in your pocket, the old one will come out fine and be re-used....never fails. It will only rip if you DONT have a spare.
That inner bearing is a mother to get out/in. I decided not to pull the entire motor just to press a bearing and swap it while on the bike. My handy bearing puller kit wouldn't work. I had to create a device compiled of a piece of threaded rod, washers, nuts and chunks of 2x4. Looking back, I should've taken pics of my concoction since it actually worked pretty slick....it only "looked" hokey.
I'll for sure do that, and I know exactly what you mean! I go through the same thing here!Meatball wrote:Get a new oil seal also for the inner bearing nearest the tire. If you don't have one on hand when you remove the old one, it will rip for sure. I bet if you have a new one in your pocket, the old one will come out fine and be re-used....never fails. It will only rip if you DONT have a spare.
In my Honda Service Manual, it shows they have a special tool (kinda like a "punch" or something), not sure if it's still available or not, should be, but if it isn't, I'll haft to do something like you did!
Basically you just fill it through the drain hole until its full and starts spewing out. I let the extra dribble out before I put the bolt in so its not over filled. After the first few pumps I spin the tire by hand to make sure its where it should be, then continue filling.
Myself, I use a pump as pictured below. They can be had for $5-$10 pretty much anywhere. I get mine from Walmart in the boat/marine section. The supplied hose doesn't fit into the fill hole so I attached a small 3" piece of vac hose (drinking straw works too) to the end, works great.
I cant remember if it was Wheelman or PatTheSoundGuy who once posted as using a Ketchup/Mustard bottle with a pointy tip purchased from the Dollar Store. Just shove the tip in and squirt!
- gear oil pump.jpg (35.52 KiB) Viewed 22850 times
Meatball wrote:Basically you just fill it through the drain hole until its full and starts spewing out. I let the extra dribble out before I put the bolt in so its not over filled. After the first few pumps I spin the tire by hand to make sure its where it should be, then continue filling.
Funnel schmunnel.
You can buy a 50cc syringe at the Dollar store,. Measures and injects precisely.
Funnel schmunnel.
Thanks wheelman! I'm gonna look for one of those!Wheelman-111 wrote:Greetings:
Funnel schmunnel.
Ruckenstein
Funnel schmunnel.
OR
you can get a free one at a CVS or Walgreens pharmacy dept. just go to the desk and ask for one. Just make sure you look uber disheveled and be scratching your arms like crazy. Works every time.
Seriously though...just ask. No theatrics necessary.
http://www.autozone.com/greases-and-gea ... 991558_0_0
i've been using this, fill up 10w-40 if needed, or whatever service book listing for.
i got the gear if ya need it
Thanks for the help guys! I'm trying to get some parts around to do job. I'll update this page as I start the work on it though.
